Old 05-07-2016, 06:28 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Crack between water passage & cylinder death knell?
Got a 21 stud that has a hairline crack between water passage way and # 2 cylinder. The cylinder has been sleeved and the crack has been repaired by drilling it out and installing stud; anyway that's what it looks like to me. Is this the end of the road for this block? I pulled the heads because it had low compression on all cylinders after rebuild.
36tudordeluxe is offline   Reply With Quote
Old 05-07-2016, 09:49 PM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: Crack between water passage & cylinder death knell?
Frank Casey could probably pin it, he's done several for me and we didn't even have to sleeve it. How far into the valve pocket does it go?
Old 05-07-2016, 10:03 PM   #3
36tudordeluxe
Ol'Ron, the crack doesn't extend into or towards the valve pocket; it runs to the cylinder sleeve and the other way up to the head stud.
Old 05-07-2016, 10:11 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
I'd run that.
Ken/Alabama is offline   Reply With Quote
Old 05-07-2016, 11:43 PM   #5
WestCoast
to me it looks like the crack ran to the cylinder but was sleeved to repair it, its fine just find why the low compression, bad rings or burnt valves, either of those are your problem
WestCoast is offline   Reply With Quote
Old 05-07-2016, 11:48 PM   #6
36tudordeluxe
Originally Posted by Ken/Alabama View Post
I'd run that.
Ken, value your opinion and thanks for responding. I was hoping the general consensus of those responding would be encouraging & positive. Upon pulling the aluminum heads there appears to be an electrolysis problem as there is some erosion in the mating surface of the heads; just read on this site the heads can be pressure tested and that may be my next step when I'm totally confident in the block.
Old 05-08-2016, 12:56 AM   #7
36tudordeluxe
WestCoast, I like your opinion on the crack; I also thought that it was repaired in the manner you described. You must also be psychic, it does suffer from low compression!
Old 05-08-2016, 01:27 AM   #8
40 Deluxe
Any idea of how long ago that cylinder was sleeved? Or how many miles it has gone since? Chances are that repair could have been done over 60 years ago.
Old 05-08-2016, 06:03 AM   #9
Terry,OH
Terry,OH's Avatar
This type of crack is not the end of the line for this engine. It looks like a nice repair job. The sleeve was probably installed because the crack did run down into the cylinder and the sleeve guaranteed a good final repair. I too would run it.
Old 05-08-2016, 11:53 AM   #10
flatjack9
flatjack9's Avatar
Looks to me like you have some kind of head gasket problem. There should be no coolant in the area that shows corrosion, therefore there should be no electrolysis in that area.
Old 05-08-2016, 11:57 AM   #11
36tudordeluxe
The cylinder was sleeved in '98 or there about, am thinking the crack was repaired way before that. the engine has less than 400 miles on it.
Old 05-08-2016, 12:00 PM   #12
36tudordeluxe
At assembly I used sealant on both sides of the head gasket and used correct torque sequence, re-torqued heads after 2 heat/cool cycles.
Old 05-08-2016, 02:03 PM   #13
JSeery
JSeery's Avatar
May be a problem with the head or the block surface not being flat. I would have them both checked.
Old 05-08-2016, 03:49 PM   #14
Ronnie
Ronnie's Avatar
Have heads checked for warpage and then resurface anyway. I think you will find warpage.
With modern antifreeze there is little concern with electrolysis.
R
Ronnie is offline   Reply With Quote
