#1 |
I have an Ahooga horn. It works OK.
I don't know what it's from? It has NO bell on the front. someone once mentioned it came from a truck. I can post a picture tomorrow Any ideas? Thanks Jim |
#2 |
KLAXON made ahooga (motor driven) horns for GM cars. My 29 Chevy has one with a slight taper on the trumpet, but no bell mouth on the end like the Model A.
#3 |
Check the bottom of the motor mounting rim for identification stamps;
#4 |
Here are some motor types;
Recessed screws, Sparton The other is Stewart Warner
#5 |
Some are very faint. Carefully remove the paint with liquid paint remover to reveal the imprinting. Then match it with Mike's examples.
Good enough.. Isn't. |
#6 |
#7 |
Did the model A's ever come with a Stewart Warner horn?
When I bought my 30 Briggs Town sedan, it had a Stewart Warner horn, that always sounded weak and sluggish.
Brian French; 1930 Briggs Town Sedan |
#8 |
Yes, in fact that might be the most common brand. Look closely around the flange for a name that is lightly stamped in.
#9 |
Tom: Yes, it is stamped in script. "Stewart Warner". "Made in U S A" , so, that likely was the original, "correct" horn for this car.
I notice the brushes are much smaller, in fact the entire motor is smaller, than the Sparton horn I just installed. I am hoping I can get this one working strong again. Thank you for the guidance, Tom. I really appreciate your response. Thank You.
#10 |
Can you post a picture of the Stewart horn?
They shouldn't be much different than the Sparton as far as size and sound. |
#11 |
The SW horn I restored for Dads car last summer has a very nice sound. I almost swapped horns with him as it is slightly louder than my Ames. Guesse I will see how the 2 Spartons that are on the bench sound before I make a decesion on which one to keep. Rod
#12 | |
![]() Quote:
I notice the brushes are smaller, the armature is smaller, the field coils are smaller, and have extensions. Does this horn look like an original? Thank You
Brian French; 1930 Briggs Town Sedan Last edited by Brianfrench65; 05-12-2016 at 01:21 PM. Reason: Add text |
#13 | |
![]() Quote:
This may help as well, https://www.fordbarn.com/forum/showthread.php?t=49464
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 05-13-2016 at 12:49 AM. |
#14 |
Mike; thank you, that was very informative.
Thank You.
#15 |
A recurring enlightenment whenever Stewart Warner horns are discussed is, the screw holding the waved vibrator disc to the armature is LEFT HAND THREAD. Don't twist it off!!
#16 |
So.....if Stewart Warner horns were standard equipment for Ford, when did the Sparton horn come into use? Was it just sold as a replacement horn? Did the dirt roads beat the horns up to the point, you needed to replace them?
Just curious, and trying to learn. Thank You.
#17 |
They were one of 5 manufacturers Ford used during production. Most all at the same time. See the Judging Standards for changes and time line. Rod
