#1 |
I retorqued the heads on my engine this weekend and managed to break two of the nut covers on the heads. I see the nuts covers are available readily, but does anyone use actual acorn nuts on the heads. If so , who is a good suppliers for those?
Thanks, John
Houston, Tranquility base here. The Eagle has landed. |
#2 |
Are you saying that you re-torqued the heads with the nut covers in place?
If so, just replace the broken ones with new ones. |
#3 |
Someone on Ebay lists acorn nuts for around $250.00 set of 48. Acorn nut cover sets for $15.00. Real acorn nuts are definitely form over function.
"Never complain,never explain"... Henry Ford II |
#4 |
Took all the nut covers off, and found corrosion under several of them. I initially didn't realize they were just covers.
So is it correct to have the covers, or is that just a dress-up item added by owners? There are considerably cheaper prices than $250 for actual acorn nuts if you buy from a hardware vendor. If someone wanted to get together a number of buyers, they can be had in quantity at a relatively cheap price. |
#5 |
Got my "real" acorn nuts from Flathead Jack for $125 per set of 48.
Flat32 ![]() |
#6 |
#7 |
Real acorn nuts don't weep coolant when you have studs. I heard somewhere that some Model A's had them from the factory.
Flat32 ![]() |
