Old 04-16-2016, 03:22 PM   #1
Flat32
Default Scale engine project
Last reference to my project was in this thread: https://www.fordbarn.com/forum/showthread.php?t=194065.
Not wanting to hijack I decided to create my own threads and see how it goes.
Starting with a pic.
Flat32
Flat32 is offline   Reply With Quote
Old 04-16-2016, 05:02 PM   #2
JSeery
JSeery's Avatar
Default Re: Scale engine project
Very interesting, are they used in anything or just set up and run on a stand?
Old 04-16-2016, 05:48 PM   #3
Flat32
They are PLA plastic models, true to scale with full details, that I 3D print. A running engine made from metal castings is a huge undertaking that can take years. Begins with a successful 1/4 scale block casting. Working on it, but need help.
Flat32
Old 04-16-2016, 05:52 PM   #4
corvette8n
corvette8n's Avatar
Nice work, maybe someday someone will be able to 3D print a full size metal block, then we won't have to worry about finding crack free old blocks.
Old 04-16-2016, 06:13 PM   #5
FrankWest
FrankWest's Avatar
Remember these
http://www.amazon.com/Revell-85-8883...gine+model+kit
FrankWest is offline   Reply With Quote
Old 04-16-2016, 06:36 PM   #6
Flat32
Never had one of those, but assume it is pretty much a generic overhead valve engine. Mine will be an accurate representation of a Ford 59A engine. Haven't modelled the carb, fuel pump and crab distributor yet. Long way to go.
Starting out I was intending to do only a bare block.
Flat32
Old 04-16-2016, 06:43 PM   #7
27lizzie
In your pic it shows 5 blocks. what is the scale range. Marlon
27lizzie is offline   Reply With Quote
Old 04-16-2016, 07:28 PM   #8
Flat32
Large brown one is a 1/4 scale raw casting version representing the block with no machining. Large gray one with heads is 1/4 scale but fully machined representation missing only threads in the bolt and stud holes. Can't print them.
Three remaining gray ones are 1/6, 1/8 and 1/12. I can print them in any scale within the printer's limits, but smaller the printing layers become more evident and holes start getting lost smaller than 1/12. Keep in mind all of these have all the water jackets and true to scale wall thicknesses.
Click on the thumbnail picture and I think it will take you to my Photobucket where you can see more by clicking around.
Flat32
Old 04-16-2016, 10:33 PM   #9
RalphM
RalphM's Avatar
Wow! That's pretty neat, how do you get the water jackets and internal details to print?
RalphM is offline   Reply With Quote
Old 04-16-2016, 11:09 PM   #10
Kahuna
Kahuna's Avatar
Incredible work Flat.
Thanks for sharing
Jim
Kahuna is offline   Reply With Quote
Old 04-16-2016, 11:35 PM   #11
Scotty's 52 F3
Scotty's 52 F3's Avatar
Very cool!
Scotty's 52 F3 is offline   Reply With Quote
Old 04-17-2016, 12:44 AM   #12
vilanar
Wow ! Countless amount of hours behind the computer .... Impressive...
vilanar is offline   Reply With Quote
Old 04-17-2016, 05:59 AM   #13
aonemarine
aonemarine's Avatar
You would be surprised what 3d printing can do. I actually met flat32 awhile ago over the discussion of being able to print the block. That was the first hurdle, next is the casting....Not an easy task! It takes a special type of devotion to pull off what he is doing with this project.
aonemarine is offline   Reply With Quote
Old 04-17-2016, 08:52 AM   #14
JWL
None of us realize nor appreciate what is required be done BEFORE any 3D printing can begin. The Printer has to be instructed on what to do and how to do it. In the example of these blocks the Ford drawings have to be put into a format transferable to the Printer. Believe me, it can take hours and hours to "back" your way into the dimensions or interpret the Ford drawings. Then you must be capable of "drawing" those dimensional characteristics on your computer screen. This doesn't even consider educating yourself on what or which printing compound materials will give reasonable results.
Overall just an astounding bunch of frustrating work most people are not(including me) equipped to do.
JWL is offline   Reply With Quote
Old 04-17-2016, 10:13 AM   #15
Ol' Ron
Ol' Ron's Avatar
My grandson is now working for a company that is making some of the 3D printers that work other materials, and printing a flathead block is not that far in the future. I hope I live long enough to get one. But as he says, "Programing is a bitch". Also some of the stuff is behind closed doors.
Old 04-17-2016, 10:21 AM   #16
oldford2
oldford2's Avatar
Too amazing for my feeble old mind to comprehend. Just wondering what you do in your spare time
oldford2 is offline   Reply With Quote
Old 04-17-2016, 11:39 AM   #17
RalphM
RalphM's Avatar
I know all about the casting/ machining part. My Dad is a pattern maker, he has done countless models, core boxes, match plates, etc through out his life. I grew up around all of it, although I could never do it myself, I know the process. Of course all of this was BC (before computers) and he figured all of it out in his head and on paper.
And before CNC machining.
Old 04-17-2016, 11:51 AM   #18
Tinker
Tinker's Avatar
Very cool project, thanks for sharing.
Old 04-17-2016, 09:48 PM   #19
Flat32
My first manifold was made before I had any CNC machine and all of the patterns and core boxes were made in my kitchen from hydrocal plaster over a 4 month period while my wife was back in Taiwan.
Models to make the core boxes were made from various materials including plastic flex hose, clay, carved styrofoam, wax, and some cut pieces from a stock aluminum manifold. Made two castings poured by a foundry that told me the mold would fail. He charged me $1200 for the two trial pours that turned out good. One of them I gave to JWL as a raw casting that he finished up and dyno tested. It's in his book. The experience dealing with the foundry lead me to learning the entire mold making process, building a foundry furnace and subsequently making my own castings. Then got a CNC machine and learned how to use it. Make patterns now with CNC and machine all of my castings with it. My beloved Tormach PCNC 1100.
I'm currently hung up on making the core boxes for the 1/4 scale block water jackets. The water jacket cores in full size are easier to do than small scale ones because of how fragile the small ones are. While making the core boxes using RTV silicone is logical the damned stuff shrinks in varying ways.
Henry's core boxes were cast iron and I'm trying to duplicate their design, but can only guess how they were constructed. Need help on this one.
Flat32
