Old 04-09-2016, 06:19 PM   #1
Tom F OHIO
Tom F OHIO's Avatar
Default Wheel Bearing Clip Ring
Is there a trick to get the back hub bearing clip ring out without breaking it. Don't see any holes on the ends to take it out.
Thanks,
Tom..........
Tom F OHIO is offline   Reply With Quote
Old 04-09-2016, 07:00 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Wheel Bearing Clip Ring
It should have a bevel on the end that the screwdriver can lift and set to the side of the groove, then just keep going around walking it out of the groove. Actually I lift the end up enough to slip a small screwdriver under it so it can't pop back into the groove.
Old 04-09-2016, 07:58 PM   #3
Tom F OHIO
Tom F OHIO's Avatar
Thanks I will give that a try.
Old 04-10-2016, 01:07 PM   #4
JBill
Wear safety glasses. They're springy.
JBill is offline   Reply With Quote
