Old 04-04-2016, 02:10 PM   #1
Carb Guy
Carb Guy's Avatar
Default Clutch release shaft arm
Broken arm. A while back i said on the Form that I had clutch problems and depressed the clutch and could not shift. pulled the rear end and removed the transmission and bell housing. Did not find anything broke or wrong. Went ahead and ordered a rebuilt clutch pressure plate, new clutch disk, new throw out bearing and pilot bearing. Had the pressure plate and flywheel balanced. put it all back together, and on final assembly my son who did all the work, I just handed him the tools, was under the car and we were hooking up the adjusting arm and trunion to the lever arm, he said the arm is cracked in two, and said this might have been the problem right from the start. Well it is a shame that I did not see this right away if that was the problem. anyway have all new now and shifts just fine, good for another 40 years
Carb Guy is offline   Reply With Quote
Old 04-04-2016, 03:33 PM   #2
700rpm
700rpm's Avatar
Default Re: Clutch release shaft arm
A common problem. Always check for the easy stuff first.
Ray Horton, Portland, OR
Old 04-04-2016, 03:51 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, a fairly common problem. Now we are going to have to carry a portable welder on road trips.
One guy actually finished the trip by clamping a pair of curved jaw Vise Grips on the break.
Old 04-04-2016, 04:07 PM   #4
Mitch//pa
I thought back on your original post it was mentioned to check the arm????
Old 04-04-2016, 05:28 PM   #5
Carb Guy
Carb Guy's Avatar
It may have been mentioned to check the arm and if it was unfortunately I missed it. I was not aware that it is a fairly common problem. Oh well all water under the bridge now. Thanks for all your help
Old 04-04-2016, 08:15 PM   #6
2manycars
2manycars's Avatar
My brother had the same problem on his doodlebug, and when he described the problem to me, I told him then, on the phone that the arm was broken. He replaced it and is now happy.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 04-04-2016, 08:19 PM   #7
700rpm
700rpm's Avatar
CG: I went back and read the posts around your first question, and didn't find a reference to the arm either. We slipped up on the advice there, if I was looking at the right thread.
Old 04-05-2016, 07:00 AM   #8
Carb Guy
Carb Guy's Avatar
Hello Ray
I also went back and looked at the original discussion and could not find any thing about a broken arm. It is good that is all up graded now. Thanks to everbody
Old 04-05-2016, 08:44 AM   #9
SeaSlugs
SeaSlugs's Avatar
don't the vendors sell a heavy duty machined one? Sure doesn't look as pretty but this is one of those parts that functionality trumps looks.
were the broken arms as common when the model a was new and everywhere? I cant say I've seen alot of broken ones around or rewelded ones...ive seen just about everything else farmer fixed except that arm...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-05-2016, 08:48 AM   #10
jeep44
I had basically the same thing happen on my 8N tractor-the clutch arm was cracked on the side I couldn't see, and so I split the tractor and changed the clutch. D'oh!!
jeep44 is offline   Reply With Quote
Old 04-05-2016, 09:54 AM   #11
100IH
Also wondering, now that the issue has been resolved, Is the engine any different ie,
smoother running after the fly wheel and clutch assy. has been balanced?
100IH is offline   Reply With Quote
Old 04-05-2016, 01:52 PM   #12
Carb Guy
Carb Guy's Avatar
Yes the vendors sell a replacement arm. I had an old housing out in the shed that I was able to get the arm off of and used that. I will have to keep an eye on it.
I have not been able to get my car on the road to test things. It is so wet and I have to drive my car over my lawn to get from the back garage to the street. My flywheel and the old pressure plate where balanced, so there may not be any difference, will see.
