Old 03-21-2016, 03:20 PM   #1
old31
Default 31 deluxe roadster shock parts
Does anyone know were I can get a wingshaft for a 30 right front shock. The part number on the cover is 1426115-1499660.
I spoke with John Holland, he did not have any that he could part out.
Old 03-21-2016, 09:54 PM   #2
Brian SATX
Brian SATX's Avatar
Default Re: 31 deluxe roadster shock parts
I have 4 that I could let go if you are interested. That number is the patent number that is stamped on them correct?
Brian SATX
Brian SATX is offline   Reply With Quote
Old 03-22-2016, 03:10 AM   #3
31 RPU
Is this the main shaft that the shock arm mounts to?
Do these interchange between earlier shocks and the later ones?
31 RPU is offline   Reply With Quote
Old 03-22-2016, 03:52 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
It's the rotor.
info on the shocks
Old 03-22-2016, 08:13 AM   #5
old31
This is the piece that is needed.
Old 03-22-2016, 08:55 AM   #6
31Tudor
31Tudor's Avatar
I believe that is a CW and a CC piece. You would need to be sure that you are getting the same piece. They have a check valve in them that only works one way.
31Tudor is offline   Reply With Quote
Old 03-22-2016, 10:26 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
They were fitted and there are different designs, one from other shock most likely won't interchange and work properly, and if that part is good most likely the rest of the shock is good
Old 03-22-2016, 11:13 AM   #8
old31
Yes it is. I am not sure on the interchangeability of the wingshafts.
Old 03-22-2016, 04:41 PM   #9
jw hash
jw hash's Avatar
it is not just that easy, there is around 37 different shock for the Model A. and to find the right one is not going to be easy. what you are showing is two peaces the wing shaft and the chamber divider wall. it looks be froze to the wing shaft. I think you would better off finding another shock for rebuilding.
jw hash is offline   Reply With Quote
