Old 03-15-2016, 07:50 PM   #1
Old Henry
Old Henry's Avatar
Default Yet an even higher flow thermostat?
I just received a PM tipping me off to what appears from pictures to be an even higher flow thermostat than the Stant stat that I have previously found to be the highest flow of any that I've studied. This one is a MotoRad High Flow Thermostat (their part # 2003-195) that also fits the 1990 Subaru Justy and the Ford 59A engines like the Stant 14157 does. I would probably be interested in them if they weren't 195°. For any that likes running their 59A that hot it looks like the best thermostat I've seen so far.
Here are the two thermostats side by side. The Stant on the left and the MotoRad on the right. What do you think?
