Old 03-03-2016, 06:32 PM   #1
theHIGHLANDER
Default 39 dlx/std dash dimension needed
I decided to start making the parts I've had trouble finding. I'm down to the center bezels on the dash panel that flank the speaker grille on both sides. I could likely guess the ashtray but the depth of the 3 remaining knob bezels? Not a clue. If someone has a dlx or standard could you share a nominal depth to the openings? In the pictures you can see what I mean and how I'm going about making them. The choke, throttle, cigar lighter and ashtray pull all sit in the "D" shaped openings. Thank you very much for the help.
theHIGHLANDER is offline   Reply With Quote
Old 03-03-2016, 06:37 PM   #2
theHIGHLANDER
Default Re: 39 dlx/std dash dimension needed
Here is a picture shagged from a google image search showing the finished parts:
