Old 02-28-2016, 04:35 PM   #1
ford-m
ford-m's Avatar
Default 29 Roadster top irons make over
Spent the weekend dismantling the top irons from the cross bows.
Chiseled out the old rotten material.
Large bow had a hardened rock like material and tow other bows had a layer of what seemed like pressed cardboard and a layer of 1/4 wood.
I will be steaming new wood strips to bend them and install them.
Bows are off to the sandblasting shop tomorrow.
ford-m is offline   Reply With Quote
Old 02-28-2016, 09:34 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: 29 Roadster top irons make over
What are you planning on replacing the fill/tacking material in the bows with?
Randy in ca is offline   Reply With Quote
Old 02-28-2016, 10:08 PM   #3
Spokes
Where did you use the Corona ???
Spokes is offline   Reply With Quote
Old 02-28-2016, 11:44 PM   #4
Mike Peters
Mike Peters's Avatar
I also would like to get some ideas about what to use for nailing inserts for these top irons.
Am working on a 28 Phaeton with top irons in similar condition to your own. No one sells anything for this that I am aware, only straight top bow wood. Thanks
Mike Peters is offline   Reply With Quote
Old 02-29-2016, 01:58 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
How would something like this work for you?
https://www.lebaronbonney.com/cart/itemdesc.php?ic=5039
or
https://www.lebaronbonney.com/cart/itemdesc.php?ic=5040
Old 02-29-2016, 06:31 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Steaming thin strips and gluing with water soluble glue is how we do them too however one word of caution, you need to make a fixture to to hold the top irons in the correct curvature in that area. The first ones we ever did actually tried to straighten out in the curved area as the wood dried.
As for the tubular rivets, use brake line tubing. Cut an extra long length of tubing and cut the end at 45 degrees. Drive the piece in until you can cut the 45 degree end straight. The end you were hammering on with be damaged too, so cut that end too and then use a tool that you fabricate in a lathe to roll over the ends.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-29-2016, 07:26 AM   #7
tinman080
tinman080's Avatar
Try buggy.com (Justin Carriage Works originally) click on the buggy breakdown pic for parts. They have steam-bent oak bows in different widths for a crazy low price ($18.00), I used these when I built my 1903 Olds. There is plenty of end length for trimming and fitting. Best of Luck, Gary
Just Passin' Thru.....Slowly!
tinman080 is offline   Reply With Quote
Old 03-27-2016, 03:12 PM   #8
ford-m
ford-m's Avatar
Continuing with my to irons today I spent considerable time trying to keep it original wood. This turned out to be too much and I elected to use some plastic I had around the shop. Bends super easy and will accept nails/screws and will last forever. I tried steam bending the wood but it wasn't working for me.
Cut strips of 1 1/4 x 5/16 plastic stock to size
Round over one side to fit inside bow.
I mitred the end to fit the tapered bow end. I used the old pieces I took out as a template
Finished product (almost). I still had to hammer like heck to get it in there.
Old 03-27-2016, 07:49 PM   #9
Mike Peters
Loved your solution! After tho top is installed, none of the plastic will be seen, yet it will hold nails/screws. I will be doing something similar when I get to the top irons on my 28 phaeton. I restored a '15 T touring a couple years ago and ran into the same problem with the tack rails for the front and rear seats. New wood was not available, but a supplier of Model T wood did sell plastic strips that made a wonderful wood substitute for tack rails. The plastic conformed perfectly to the seat backs and held upholstery tacks very well.
Old 03-28-2016, 10:18 AM   #10
Classiccanuck
Classiccanuck's Avatar
Nice! great idea, I've been holding off doing my bows for a while now, where did you find the plastic you are using?
Classiccanuck is offline   Reply With Quote
Old 03-28-2016, 04:06 PM   #11
ford-m
ford-m's Avatar
The plastic I had in the shop lying around. Bought it from these guys years ago to rebuild a dash on a boat. I believe it was called starboard
http://www.masplastics.com/about/about.php
Old 03-28-2016, 04:10 PM   #12
ford-m
ford-m's Avatar
Here they are with all the plastic installed. It went a lot easier than I thought and even easier once I introduced the heat gun to warm them up before pounding them in.
Now to fasten the wooden bows, I will use Brent's idea of the break lines and peen them over.
Thanks for the idea Brent
Old 03-28-2016, 07:49 PM   #13
Classiccanuck
Thanks! enjoying the pic's you have been posting, keep it up.
Old 04-11-2016, 03:55 PM   #14
Classiccanuck
Could not find any distributor of "Starboard" willing to sell anything less than a 4'x8' sheet ($258 CDN). Bought a couple of polyethylene kitchen cutting boards and cut into strips, seems to bend easy with a little heat.
Old 04-11-2016, 04:20 PM   #15
ford-m
ford-m's Avatar
That should work. Same type of material.
Old 04-11-2016, 04:28 PM   #16
Classiccanuck
checked out product information, and Starboard was also a polyethylene. Going to round over the edge and try them out.
Old 04-11-2016, 05:27 PM   #17
pooch
pooch's Avatar
As staples are usually used these days, I would like to know how good this stuff grabs the staple ....
pooch is offline   Reply With Quote
Old 04-11-2016, 09:06 PM   #18
ford-m
ford-m's Avatar
I did some test shots in some spare plastic i had before I installed it and the staples stuck to the plastic like $hit to a goose. Had trouble prying the suckers out. I'm using 3/8 stainless upholstery staples.
Here they are painted. I also sprayed mould release agent befor the epoxy primer and paint to get the best adhesion.
Old 04-12-2016, 01:43 PM   #19
Classiccanuck
shot a few staples into the "cutting board" material, no problem, had to use side cutters to pry staples out.
Old 04-12-2016, 04:48 PM   #20
Classiccanuck
Ford-M, how thick did you cut the plastic you used?
