02-26-2016, 12:59 PM | #1 |
40-41 pickup RH running board hole?
Whats the hole for?
02-26-2016, 01:17 PM | #2 |
Re: 40-41 pickup RH running board hole?
Guess,,,,spare tire bracket ?
02-26-2016, 01:21 PM | #3 |
I believe it is a carryover from 39 when the spare tire was mounted on a stand up casting mounted to the running board. Cost reduced in 40 to the stamped bracket that was riveted to the bed side ( which almost all failed at the rivet and farmer welded back on). The hole was left in.
Just my opinion. |
02-26-2016, 04:42 PM | #4 |
Hole also allows water that might collect under the tire to drain.
02-26-2016, 05:09 PM | #5 | |
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
02-26-2016, 09:20 PM | #6 |
02-27-2016, 04:37 PM | #7 |
