02-14-2016, 02:22 PM | #1 |
Kerosene in Engine Oil?
Hey Guys,
I have a '29 engine that has many, many miles of old oil in it. I heard from a seasoned car guy to add about a quart of kerosene to the oil and allow the motor to idle for a minute or so- then draining it. After that, continually flushing new 30wt oil until cleaner. Any validity or experience to this method? Thanks, Jim
"Whether you think you can, or think you can't- you're right." H. Ford |
02-14-2016, 02:38 PM | #2 |
Re: Kerosene in Engine Oil?
Do it the correct way, drop the oil pan and clean it out. Don't forget to remove the windage tray and get the gunk under it. You also might want to check the rod and main clearances and rebuild your oil pump while you are in there.
02-14-2016, 02:44 PM | #3 |
Drop the pan, see what you have. Why take a chance of clogging the pump or clogging the tubes to the bearings. If the oil sat for a few years maybe flush but unless you know of a time when it was clean I would not do it.
02-14-2016, 03:11 PM | #4 |
Think about how much oil( how many changes) it will take to, not just flush the kerosene, but the guck as well. On top of the risk Mike mentions!
02-14-2016, 03:20 PM | #5 |
About 10 years ago I drained the oil on an unknown engine, then put in 5 quarts of diesel and made an air bubbler for the drain plug. I let it agitate with air for an hour, then drained and repeated the process twice more. Then I pulled the pan to see how well it worked. It still had an inch or more of thick sludge.
Don't waste your time with any quick fix................just drop the pan. |
02-14-2016, 03:47 PM | #6 |
02-14-2016, 03:49 PM | #7 | |
02-14-2016, 04:11 PM | #8 |
Like everybody above says, DO IT RIGHT - DROP THE PAN. Who would ever listen to a used car guy anyway?
02-14-2016, 04:38 PM | #9 |
FWIW Possibility:
1. Say it took 20 years to collect abrasive silicone sand, dirt, and piston/ring iron filing buried in thick dirty grease sludge after using non-detergent oil for 20 years and not changing oil often. 2. Next ..... Add kerosene which will no doubt get heated up and dissolve some crud after oil and kerosene mix is heated and stirred up profusely by rotating connecting rods which act like an electric high RPM egg beater in a pancake mix. 3. Loose harmful solid abrasive non-liquid deposits get freed up and circulate through the 0.0015" clearances of moving engine parts at multiple RPM's, maybe at same velocities as that of cylinder honing stones in a rotating electrical drill. 4. This is in no way, not even in a twinkle of an eye, to be taken as trying to advise anyone what to do with kerosene ...... however, it may be considered to be just a little similar to Fox News ...... We report ...... you decide. Hope this helps. Last edited by H. L. Chauvin; 02-14-2016 at 04:40 PM. Reason: typo |
02-14-2016, 08:22 PM | #10 |
I think Mr Chauvin has a useful insight into this question. Whenever I have cleaned out a pan of an old survivor Model A engine I have been amazed at the amount of potentially abrasive material that is embedded in the sludge. In an engine with no oil filter, that sludge has served a purpose.
02-14-2016, 08:35 PM | #11 | |
02-14-2016, 10:57 PM | #12 |
Well- alrighty then, I shall pull the pan. I have the Model A mechanics books by Les Andrews so I'll follow his procedure.
Thanks to all, Jim
02-14-2016, 11:25 PM | #13 |
Just watch how tight you make the pan bolts. Someone said that book lists them as 20 foot pounds, but that should be inch pounds. Common sense tightening will do the trick.
02-15-2016, 12:18 AM | #14 |
I am still new to the Model A world, but I think I can offer some advice on this. I dropped the oil pan in my car because I had no idea of the history of the car. Glad I did because there was a lot of sludge in the pan, not just on the bottom, but in the baffles as well.
You will need a new set of rail gaskets as well as front and rear gaskets. Permatex gasket sealant is recommended also. Keep in mind that when you drop the oil pan, the pump comes out with it, so be ready for this. Also, you will want to remove the baffle for cleaning the oil pan. I have seen instructions written somewhere to pry it out, but if it's stuck, prying will bend it. I took a cut off section of an old shovel handle and put it through the bottom of the pan. One pop with a dead blow hammer, and the baffle was out. (This is now an official component of my Model A tool collection) All in all, this is not a difficult task, I hope it goes well for you. |
02-15-2016, 01:46 AM | #15 |
Turn the pan upside down over a sheet of plastic and drop on the floor with a little umph. Baffle should pop right out. Be ready for a little splatter.
02-15-2016, 02:31 AM | #16 |
You can also place the pan in a bag before dropping it to reduce splatter.
02-15-2016, 05:42 AM | #17 |
Remember when turning a pan or cover bolt when you get to the point where you are thinking'' Gee I don't wanna break this off- you are at that point.....'' Ask me how I know....All makes and models fall under this natural law....LOL
Just Passin' Thru.....Slowly! |
02-15-2016, 08:03 AM | #18 |
Please do what the above posters say- My current project is a 1914 Maxwell the engine turned by hand great and looked like it ran yesterday... removed the head to find nut shells (handful) in the #1 and #3 piston and a bunch of leaves and a crackerjack toy in the pan, took hours n hours to remove the head but when I saw what was inside an otherwise clean,tight engine glad I did !!
02-15-2016, 10:33 AM | #19 |
I knew a man that would do the Kerosene trick every oil change. Ran a 1956 Dodge Station wagon almost 1,000,000 miles. I could see it working here, but not on a engine you know nothing about.
02-15-2016, 01:22 PM | #20 |
Similar to what Mr. Tinbasher is saying about a meaningful "cleaning trick" & very clean lubrication that works with detergent oil used in "clean" engines:
I know of an owner who has about five large trucks hauling tons of limestone daily who changes "detergent" oil far more often than that recommended by the truck manufacturer ............. plus every other oil change, he flushes with added automatic transmission fluid (ATM) to keep "all" of his oil looking like honey as opposed to dark coffee. He claims his overstressed engines and drive train rebuilds and repairs are scheduled at about 1/10th as often as his large truck owning competitors ....... plus, as high as oil is, fresh clean oil under such stress is far cheaper than rebuilds ...... and another added bonus ....... far less down time waiting for trucks to be repaired and engines rebuilt. |
