Old 02-02-2016, 09:59 PM   #1
flatford39
Default Some advice on 8BA pistons
Rebuilding a Mercury 8BA motor. 1953 I think. It's time to buy the pistons and it's not as easy as doing a SBC. This is a stock bore that has been bored out .030. It also has a 4" crank.
So I am looking for 3.2175 pisons that are compatible with the 4" crank.Has anyone used to .030 over Sealed Power pistons that Summit Racing is selling. They are four groove but they don't differentiate between a 4" crank and the ford 3.75 crank.
Should I be concerned??? Are there camshaft clearances with the longer stroke???
Internals on this engine will be pretty much stock.
Thanks for any help.
flatford39 is offline   Reply With Quote
Old 02-02-2016, 10:19 PM   #2
Diavolo
Diavolo's Avatar
Default Re: Some advice on 8BA pistons
Pistons should be matched to the stroke. The rod is the same and the crank stroke will push the wrist pin higher in the bore. If you are using a 4" (255) crank, you need the matching pistons for the 4" stroke. If you don't, you will have a bad day.
If you look at the selection from Summit Racing, you will see that the only stroke offered is 3.750. Here is the link. http://www.summitracing.com/search/p...rd-flathead-v8 You need pistons for 4.000 stroke with the 4" crank.
Seek another vendor, maybe reds? I personally would go with a machinist that knows flatheads and let them buy the pistons according to my preference and do the machine work.
Diavolo is offline   Reply With Quote
Old 02-02-2016, 10:22 PM   #3
flatford39
Thank you...That's what I thought. Look's like I will give Van Pelts a call in the AM.
Old 02-02-2016, 11:00 PM   #4
Ronnie
Ronnie's Avatar
I believe the sealed power number is W1014p but I think they are only available in .040" no other sizes.
The badger number is P135 ask the members here someone may have them they came in lots of over size's.
R
Ronnie is offline   Reply With Quote
Old 02-03-2016, 03:34 AM   #5
flatheadmurre
flatheadmurre's Avatar
An Egge set not sure how customs and shipping will turn out.
http://www.ebay.com/itm/Ford-Mercury...pVtrQ1&vxp=mtr
Old 02-03-2016, 06:00 AM   #6
Mac VP
Mac VP's Avatar
The size you gave is 0.300" over standard......you sure that is correct? Or are you looking for 0.030" oversize? We should have the.030" in stock. I sure don't have .300"........
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 02-03-2016, 07:44 AM   #7
34PKUP
34PKUP's Avatar
Oooop's, too early in the morning?
34PKUP is offline   Reply With Quote
Old 02-03-2016, 07:49 AM   #8
Bored&Stroked
Bored&Stroked's Avatar
3.2175 is .030 over . . . but maybe he want back and changed the number?
Old 02-03-2016, 07:52 AM   #9
34PKUP
34PKUP's Avatar
Nope, post would have shown that it was edited.
Old 02-03-2016, 07:56 AM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
If your using a 4 inch crank you have to use a piston that is 1/8 shorter from the center of the wrist pin to the top of the pistons than the 3-3/4 crank piston. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 02-03-2016, 09:25 AM   #11
GOSFAST
GOSFAST's Avatar
Don't know your budget but can help with some really nice Ross forged pieces for the 4.000" stroke and a finished bore of 3.228", these would be +.040 over and have the special "moly" metric ring pack.
They help with the balancing operation being only 316 grams with a 120 gram pin and a 30 gram ring set. The cast 4-ring pistons weigh over 400 grams and use some 65 gram rings.
These Ross pistons (see below) are more expensive than the conventional cast/4-ring pieces but are well worth the cost for what they add to the build. We do stock the cast pieces also but only in +.030's or +.060's with the 4 "cast" rings!
Thanks, Gary in N.Y.
P.S. These pistons with the metric rings free-up a whole bunch of HP in the Flatheads whether your looking for it or not. This is the ONLY size I keep available here (forged) for the 4.000" stroke.
GOSFAST is offline   Reply With Quote
Old 02-04-2016, 07:19 AM   #12
Bored&Stroked
I checked the Summit site - all the Sealed Power pistons that they show have a compression height of 1.519 inches - which is wrong. They showed them as 8BA replacements, so they would be for 3 3/4 inch stroke. The "off the shelf" compression height for 3 3/4 stroke is 1.561", for 4" stroke it is 1.436". I have no clue where they came up with 1.519?
You should checkout VanPelt's site - he has a part number of EAC-6108S-040 that is what you're looking for.
http://www.vanpeltsales.com/FH_web/e...prices-pg1.htm
Side Note: On my recent 42 Merc stroker engine, I had Ross make a set of pistons with my exact compression height, 1.5mm, 1.5mm, 3.0mm ring grooves, lightweight pins and they also supplied a set of TotalSeal moly piston rings. I've used TS rings on other OHV builds - decided to just try them for shits and giggles on a flathead . . . will be interesting to do a leakdown once the motor is broken in.
