Old 01-30-2016, 11:57 AM   #1
burner31
burner31's Avatar
Default Teflon tie rod/drag link question-photo
I'm using the teflon tie rod/drag link kit, and I see the the inner cup on the teflon does not have a center grease hole, as the old original cups do.
My question is does this make a difference, how does the grease push through to the rest of the ball, outer cup and spring?
Am I over thinking this?
I'm going to assume the I keep the inner small grease cup to use with the teflon cups (see photo, far left little cup also has a little hole)
I'm also changing over to the short pitman arm, can you tell which is the new pitman and why I needed to change it out, look at the ball.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
