#1 |
Looking @ gaskets and would like some input on the various manufactures offerings out there. Input on fitment would be great as it seems there are (two) 2 available for my 39 P/U. Scott
#2 |
In the past the only gasket that fit right and lasted is the one from Drake. Correct cowl lid adjustment is crucial to a good seal - I learned that lesson a long time ago ....
#3 |
I have the Drake replacement for my 42, it dropped right in with no problems, of course I did glue it.
#4 |
I use the ones from Drake. As others have said the correct adjustment on the lid is very important.
#5 |
I installed the DRAKE seal 30 years ago and it does not leak. Cowl vent adjustment is time consuming but crucial. Be sure to NOT install the new seal upside down.
#6 |
#7 |
Drake or Dennis Carpenter fit fine.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
#8 |
Thanks for the input guys, ordering today. As for alignment there are several areas for adjustment.
I remember the pivot attachment below the vent on mine did have two slotted areas were I could align the vent, centering it in the cab opening with movement from passenger to driver side after checking opening and closing. It's somewhat of a two part adjustment and cramped for sure. I had removed the gear shift lever to get some wiggle room. I had a thread on this with pictures of my vent assembly. |
