Old 01-25-2016, 09:23 PM   #1
CT Jack
CT Jack's Avatar
Default 29 2 Tooth Steering Column
Looking for a 29 2 tooth steering column restored or restorable. We are working on a 29 AA fire truck for a local volunteer fire dept. and would like to replace the original 7 tooth column which is badly worn. We do not want to restore the present column as it appears to be a waste of time and money. This is an open truck and removing the column is very easy plus we have to keep the original steering wheel. Will a 29 2 tooth steering box bolt up to the existing column? If this can be done then all we would need is the 2 tooth steering box.
CT Jack is offline   Reply With Quote
