Old 01-23-2016, 05:23 PM   #1
jeffo
Default Windshield Wiper Wire Routing
I am wiring the wiper on a early 28 tudor. We bought the wire from Snyders and I am coming up about 6" short. I came out of the terminal box and came in thru the firewall, then it runs right along the firewall to the passengers side, then it runs thru a grommet on the back (cowl to gas tank clip) then runs forward thru another grommet then up thru the passengers side window pillar and then runs along the top of the window frame and stops 6" short of the of the wiper terminal pin. I can splice in a piece that will not be seen but if I am routing the wire wrong now would be the time to fix it.
Thanks
Jeff
jeffo is offline   Reply With Quote
