Old 01-19-2016, 04:29 PM   #1
1949f1
Default 1953 Mercury
Anyone know of any parts suppliers for a 1953 Mercury turn signal switch?
1949f1 is offline   Reply With Quote
Old 01-19-2016, 04:36 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 1953 Mercury
Try these guys > http://www.parts123.com/parts123/yb....Z5Z5Z50000051e
Old 01-19-2016, 05:07 PM   #3
1949f1
Thank ya. Been searching forever and ain't found one. Wasn't looking in the right place I reckon
Old 01-19-2016, 05:26 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Don't be surprised if you find out that it won't fit a Mercury.
Old 01-19-2016, 08:02 PM   #5
1949f1
It looks right from the picture but I was told they are different. I can hopefully force it if I have to. But i would rather use the 60s junk I have to do that what would yall recommend?
Old 01-19-2016, 08:24 PM   #6
petehoovie
petehoovie's Avatar
The correct part number for the harness is 1M-14486A and C&G has it at this link > http://cgfordparts.com/ufolder/fordp...mber=1M-14486A
Also, I found this > http://www.egmcartech.com/store/Nos-...005314766.html
Old 01-19-2016, 09:46 PM   #7
1949f1
109 dollars. Wow. I would mak a mount for this one before that. Thank you though!
Old 01-19-2016, 11:50 PM   #8
petehoovie
petehoovie's Avatar
Well, at least you now have the correct part number....
Old 01-20-2016, 07:13 AM   #9
1949f1
Before I spend a $109 on nos parts let me ask yall this. I might could fix the one I have. We plugged a flasher into and it started smoking out of the column if I'm not mistaken (I wasn't there another man was working on it) the turn signals were working for a couple seconds before it started smoking. Now we aren't getting fire from any of the uhh 7? (Is that right) wires from the column. I was told that the only thing to do is replace or pull it and was hoping switch was reproduced.
Old 01-20-2016, 09:13 AM   #10
51 MERC-CT
51 MERC-CT's Avatar
I fixed a malfunctioning slide switch by removing the back and appropriately cleaning and lubricating it as required with dielectric grease.
I suspect that if the dim. between holes on the Ford switch were known it may be possible to adapt it to the Merc.
Old 01-20-2016, 10:26 AM   #11
RalphG
RalphG's Avatar
How hard is it to pull the horn and steering wheel on these cars without wrecking it? I'd like signlal lights on my Merc but don't dare try removing the wheel without knowing what I am getting into.
RalphG is offline   Reply With Quote
Old 01-20-2016, 11:21 AM   #12
51 MERC-CT
51 MERC-CT's Avatar
There should be a center cap that either twists or is pried off (try twisting first).
Once you have access inside then remove the center nut. Then using a wheel puller and the two 5/16" bolt holes, remove the wheel. The horn ring comes off with the wheel.
Old 01-20-2016, 12:34 PM   #13
1949f1
It's easy I've done it plenty of times. I'll see if I can't pull the one out of my ford.
Old 01-20-2016, 02:02 PM   #14
RalphG
RalphG's Avatar
Thanks for that image. I will save it for future reference. I might get brave enough to try it one day but for now this Merc is a long ways from being street legal.
Old 01-21-2016, 02:56 PM   #15
Kray_Z-1
try Baxter Ford Parts. Great bunch of guys. Phone 785-842-9256. They are Located at 131 Arkasnsas St. Lawrence, KS 66044 [email protected] I believe they also have an ebay store, but don't recollect their ebay user name.
Kray_Z-1 is offline   Reply With Quote
Old 01-23-2016, 04:33 PM   #16
1949f1
So pulled the switch today guy in town says he can try and fix it. I also checked ford switch same part except for ford has a piece that pawl rides on and it has a longer piece sticking up for pawl to attach to. Also I was looking the other day I think a studebaker switch Is the exact same as the Mercury.
