Old 01-18-2016, 02:22 PM   #1
Divco one
Divco one's Avatar
Default 16 inch wheels
Has anyone had brake Rod issues using 16 inch wheels with radials. All the radials I looked at are 8 inches wide or better. Coker and others list a radial but are not avaible at this time.
Divco one is offline   Reply With Quote
Old 01-18-2016, 05:43 PM   #2
Ron Lachniet
Ron Lachniet's Avatar
Default Re: 16 inch wheels
I just purchased a set of Coker 600-16 radials and have not mounted them yet, but they look like they will fit just fine.
Ron Lachniet is offline   Reply With Quote
Old 01-18-2016, 06:00 PM   #3
Divco one
Divco one's Avatar
The 6.00-16 is 2 inches shorter. the 6.50 is almost the same height as the stock 19 inch wheel. Coker told me they won't be in the country until March. It seems that these tires are sized like the bias and not like the P metrics.
Old 01-18-2016, 10:28 PM   #4
1929
I looked at mine tonight for that same reason, I didn't notice any rubbing on the rods, and the wheel is about half inch away. I was told there is an adjustment if it hits the rods.
1929 is offline   Reply With Quote
Old 01-19-2016, 01:08 AM   #5
C26Pinelake
Will a simple bump in the road cause this to happen or a pothole? Wayne
C26Pinelake is offline   Reply With Quote
Old 01-19-2016, 06:32 AM   #6
Divco one
Divco one's Avatar
1929' What size and brand radial did you install?
Old 01-19-2016, 11:26 AM   #7
1929
I had Crosswind 215/85R16 installed. I bought these only because one day I had to hit the brakes hard, and the car skid like a10 speed bike. I have more control of the road now with these tires. I did an emergency stop on the dime this time with no skidding. The tires look good to me but, the bumps are the same as the 21s. If you can get a smaller tire that you like, maybe it will perform better. I just didn't want that donut look after I changed the 21s.
Old 01-19-2016, 01:01 PM   #8
Divco one
Divco one's Avatar
I gave up looking for a radial that would clear my brake Rod. I installed a 6.50-16 bias with a cross section of 7 inches. I clear the brake Rod with 3/8 of a inch. I'm happy that it has the same height as my 19 inch tires.
Old 01-19-2016, 01:04 PM   #9
Divco one
Divco one's Avatar
Brake Rod clearance.
