01-17-2016, 01:20 AM | #1 |
SUN Engine Analizer Questions
Hello All, I have been looking for a Nice Sun Engine Analyzer for a little while but lately I have had some thoughts on how useful they are ??
I work on Flatheads, With Generator's and Point ignitions. As some people say " Old School " Just wondering if anyone has one and uses it ? Also I was wondering if anyone knows if these Machine's will work with solid core ignition wires ? That's would be a deal breaker if they don't . I have found a pretty nice one but the price is a little high. Just wanted to get some input so I can decide if it is worth pursuing. My assumption has always been they would be a great tool to have and the only drawback is they take up a fair amount of room. I don't mind it taking up space as long as it's useful . Thanks for any help , Mike |
01-17-2016, 02:00 AM | #2 |
Re: SUN Engine Analizer Questions
They are great in my opinion. used to use one every day about 30 years ago. I wish I had one in my garage. It is a great diagnostic tool for properly trained person. the machine pictured should have no problems with solid core wires. make sure you get all the accessories ( different connectors and adapters) , and most of all the operating manual if possible
01-17-2016, 10:10 AM | #3 | |
2nd that and make sure everything works on the tester. Also understand that the secondary ignition is inaccessable on the flatheads .... might have to rig up something for a test lead......be glad to help if needed ... |
01-17-2016, 10:27 AM | #4 |
I used to use the "HEI" adapter on the flathead coil, don't know if it was totally accurate as to voltage but it looked reasonable and gave a good picture
The version I used (SS400) didn't loke the "solid" wires of the model A, had to use a piece of insulated wire I have been looking also for one (SS400) close enough---and in my price range Last edited by Kurt in NJ; 01-17-2016 at 10:33 AM. |
01-17-2016, 12:21 PM | #5 |
I've used and owned them and often wish I still had one. Mine had a 2 gas but I never used it because I had a stand alone 4 gas. The one pictured does not look like it has cylinder kill which is a feature I used a lot. The book is imperative.
01-17-2016, 01:00 PM | #6 |
01-17-2016, 04:02 PM | #9 |
Invaluable tool if you know how to use them. Reading the trace is the most important part. You can tell a lot about what is going on inside the cylinder by reading the trace. I have two and a distributor machine. Mark Saunders @ Paramountd.com has helped me quite a bit keeping my machines working.
01-17-2016, 05:50 PM | #10 |
Hey Angledrive, do you see a big difference between your newer and older machine ? Meaning, if I am buying one or the other , should I look for a newer one ?? Thanks for all the help everyone !
01-17-2016, 06:50 PM | #11 |
newer is better as they dont use any tubes.great tool.just dont get a digital one as they dont work in real time and dont work good on point type and six volts.the one in pic is good.dont pay too much as u cant hardly give them away.i have a big collection of sun stuff and have used it for 40 years.people think the scopes and master motor teseters r worth way more than they are.now dist.teasters are differant.thay bring good money.but usually require calibration.remember sec. mirrors primary.sun has a nice book on how to interpit ossiloscope patterns.find em on ebay all yhe time.pattern is a window into cumbustion chamber.have fun with it.an u can impress your freinds lol.
01-17-2016, 07:09 PM | #12 |
The older it is, the more you have to fix. All the paper capacitors need to be replaced. Tubes are fairly easy to come by. Mark sold me a kit to do my distributor tester. The Sleuth One doesn't have as many features as my older scope so I don't use it as much.
01-17-2016, 08:07 PM | #13 |
As was mentioned before don't pay to much for one. Most of the sellers
seem to think they are worth a lot of money. I got one like the picture for $100.00 on Epay delivered to my driveway and everything works. Bob |
10-24-2023, 09:26 AM | #14 |
you can diagnose many things with a scope even weak cylinders lean mixtures.have used them for 50 years still have one.that style wont work one the new cars
10-24-2023, 12:54 PM | #15 |
Allen machines show up once in a while. Usually cheaper then the Sun machines.
10-24-2023, 10:39 PM | #16 | |
-Scott |
10-25-2023, 12:22 PM | #17 |
