#1 |
On my rebuilt steering box the shaft the pitman arm goes on to does not have a hole in it for a cotter pin. Has any one run into this before. I know i can drill a hole into the shaft but is there another way
Ford |
#2 |
Some pitman shafts use a large lock washer .
#3 |
My F1 box uses a lock washer.
#4 |
Part of 35 production used a hex nut and lock washer. It was changed in 35 to a slotted hex nut and cotter key. Make sure your sector shaft is 36 it should have the cotter pin hole.
#5 |
Terry
My understanding was that a 35 and a 36 box were different but a wonder if a 35 sector shaft would work in a 36 box and if do does it make any differences
Ford |
#6 |
35-36 housing is the same, the part with the sector bushings(35), sector needle bearings (36)--although aftermarket 36 sector kits came with thick bushings many times |
#7 |
Thanks for the info.
Ford |
#8 |
36 was the only year with needle bearings for the pitman shaft. could also be a NOSR shaft
#9 |
What is a nosr shaft
Ford |
#10 |
I think what is refered to is New Old Reproduction Stock...old aftermarket.
#11 |
Got it thank you
Ford |
