Old 01-11-2016, 01:28 PM   #1
Fred K-OR
Fred K-OR's Avatar
Default Installing distributor bushings-without "tools"
Can anyone give me some ideas on how to insert or install the bushings in a distributor without some of the tools that are shown on some of the posts on the Barn. I have none of this type of tool, only a hammer and/or a block of wood. In other words I know nothing about what I am doing. Tom Endy's post shows an insertion tool to use to push the bushings in to the body. But I do not have any of these tools so is there a simple, safe way to do it without destroying the body?
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-11-2016, 01:31 PM   #2
Tiny
Tiny's Avatar
Default Re: Installing distributor bushings-without "tools"
I would buy an arbor press. They are not that expensive. The distributors crack pretty easy when you hit them with a hammer
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 01-11-2016, 01:35 PM   #3
jw hash
jw hash's Avatar
if you have an old distributor shaft and cam put the screw in the cam and use it as a driver. that is what i use to do before I made one.
jw hash is offline   Reply With Quote
Old 01-11-2016, 01:53 PM   #4
Mikeinnj
Mikeinnj's Avatar
Fred, You could try using a piece of 3/8 inch all-thread, ( threaded rod available at local hardware stores) and a washer and a nut on each end.
Be sure the inner surface of the distributor housing is really clean and use some oil on it and on the all-thread threads. It helps to put a slight chamfer on the end of the bushing. The trick is to start the bushing completely straight, relative to the distributor surface.
If you do not have a reamer, you could "burnish" the installed bushings with an old distributor shaft chucked in a drill press.
Mikeinnj is offline   Reply With Quote
Old 01-11-2016, 02:04 PM   #5
Fred K-OR
Fred K-OR's Avatar
Thanks guys. I will give these ideas a try. This distributor is an "extra" one that I am rebuilding for backup so if I do mess up, I will still have one in each rig that works for now.
I also have machinist friend that said he could make me a insertion tool. So this may be a safe way. Will think about it.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-12-2016, 01:27 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Let me add; with two washers on the end with the nut you will be moving, and a little bit of oil or grease between the washers the grease/oil will act like a thrust bearing and be a little easier to turn.
Old 01-12-2016, 02:06 AM   #7
H. L. Chauvin
I always find it humorous that most of us were alive when a Coke or a Hersey Bar was a nickel and a pack of cigarettes was only 20 cents ....... King Edward cigars, 5 cents ....... and ...... Model A ignition points at J.C. Whitney were 15 cents a set in the 1950's.
Today, we sometimes have to be reminded that "nothing" is as cheap as that of the Good Old Days ........ and why not buy what we "need" in the autumn of our days.
Anyway, if anyone is interested in saving lots of time fiddle-farting with making bushing drivers, Harbor Freight has a Bushing Driver Set advertised today for $17.99 that I bought about 20 years ago when it was about $10.00.
It may have a (2) star rating because it is not metric for foreign made car parts ...... however ....... it can be successfully used for every Model A bushing such as bushings for Model A distributers, king pins, brake and clutch pedals, front brake lever shafts, oil pump shaft bushings, generator and starter bushings etc., etc.
Hope this helps .... just skip the fries at MacDonald's a few times .... we know we really don't need a pot belly as much as we need a Model A bushing driver.
H. L. Chauvin is offline   Reply With Quote
Old 01-12-2016, 02:15 AM   #8
mike657894
mike657894's Avatar
nice one H.L. i will put that in my cap for later on.
mike657894 is offline   Reply With Quote
Old 01-12-2016, 02:39 AM   #9
Mike V. Florida
But a bolt, 3 washers and a nut cost $2.01 (Lowes). A savings of $12.40 (using a 20% HF coupon).
Thats a 1/2 tank of gas.
Old 01-12-2016, 07:05 AM   #10
RonC
RonC's Avatar
Brattons Antique Autp parts sells distributor housings glass beaded and rebushed for $40 plus your old housing. Given you have no tools this would give you a fighting chance at being sucessful with your rebuild.
RonC is offline   Reply With Quote
Old 01-12-2016, 09:56 AM   #11
H. L. Chauvin
Mr. RonC is correct because after the $2.00 bushings are installed with a$17.00 bushing driver, a $55.00 (+) bushing reamer will be needed to ream the bushings.
Maybe get the $40.00 re-bushed distributor from Bratton's..... eat the MacDonald fries ..... and while waiting for the mail ....... run around the block to burn an equal amount of calories as that of the fries.
Like Mr. RonC ......... just expounding on one (1) way to re-bush a Model A distributor ....... and not get a pot belly.
Hope this helps.
Old 01-12-2016, 10:42 AM   #12
pgerhardt
pgerhardt's Avatar
Reminds me of my Aunt Agnus who had a sign in her bathroom that read: "Ten Sheets Only Please"!
pgerhardt is offline   Reply With Quote
Old 01-12-2016, 10:13 PM   #13
Fred K-OR
Fred K-OR's Avatar
Mike I think great minds think alike. Yesterday I went down to the shop and found a 3/8 in bolt along with 3 or so washers and found that if I put enough washers on the head of the bolt, I can screw the nut down, with washer under it, enough to push the bushing all the way in. I haven't tried it yet but I think it may work. Will post a picture of "our" great tool! BTW it didn't cost me anything because I found all the things I needed in my bucket of bolts. Off to the old coffee shop to get another cup of joe!
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-13-2016, 01:51 AM   #14
redmodelt
redmodelt's Avatar
I have found that pressing or pulling the bushing into place is easier on the casting and sometimes the bushing only will need a little reaming if any at all when you are done. If you have a small round file run it back fourth a few times in the hole to clean any burrs out first. The bolt trick works on pulling spring bushings and other bushings where you have a clear shot from both ends into place. Pounding them in mushrooms the end and just makes for more work in the end. I use a bolt so one end is locked to hold with wrench but all thread should work too.
Old 01-13-2016, 06:59 AM   #15
CA Victoria
CA Victoria's Avatar
Fred,
Glad to help another Model A friend out.
If you are not in a hurry I will make the correct size driver sleeve in the next couple of days and mail it to you. Works best to pull it in with an all thread Rod.
Send your mail address via email.
T.
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-13-2016, 10:28 AM   #16
imacrazy
Tim, I take a small saw blade and saw each bushing. being carful not to saw into the housing,
and then a socket a little smaller to drive them out, one at a time. I lubricate the new ones with WD-40 and press them in with my vice. It’s really pretty easy.
Bill
imacrazy is offline   Reply With Quote
Old 01-13-2016, 03:00 PM   #17
Fred K-OR
Fred K-OR's Avatar
Tim, thanks for the offer of help. I have the bushings out and I think this bolt idea will work. But the last few days other family medical situations have stopped me from trying it. So let me try this idea and if it doesn't work, I will get back to you.
Again thanks for the offer and I will see how the bolt thing works in the next day or so.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-13-2016, 03:34 PM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
jw,
TRICK IDEA, warming it in the oven helps, also.
pgrhart,
Pat had a sign in her office @ I.R.S, "NOT YO' MAMMA"!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-13-2016, 04:45 PM   #19
Fred K-OR
Fred K-OR's Avatar
Originally Posted by BILL WILLIAMSON View Post
jw,
pgrhart,
Bill W.
Good idea Bill. Will have to distract the wife for awhile while I do that.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 01-13-2016, 04:51 PM   #20
daveymc29
daveymc29's Avatar
Run a saw down the center of a 1/4 inch dowel (wood) and make a reamer by inserting a piece of crocus cloth or your favorite wet or dry sand paper. Chuck it up in your hand drill and carefully use it to fit the shaft to the bushings. Go easy and quit reaming when the shaft turns freely but doesn't rock in the hole. In other words, check progress often, don't rush it. No special tools needed and you probably already own all the stuff to create the reamer.
daveymc29 is offline   Reply With Quote
