Old 12-28-2015, 09:24 AM   #1
GJRoberts
Default 1930 1931 Model A Ford Accessory Tool Box
Does anyone have experience with the 1930-1931 Model A Ford Accessory Tool Box that mounts between the front frame horns? I have seen several that were hand made over 20 years ago, and they were fantastic. I now see newly manufactured ones for sale for around $225. They are designed to look like an original part of the body, rather than a clunky box shape.
GJRoberts is offline   Reply With Quote
Old 12-28-2015, 10:22 AM   #2
Jim Huseby
Jim Huseby's Avatar
Default Re: 1930 1931 Model A Ford Accessory Tool Box
Some years ago I designed a tool box that matched the shape of the frame horns. It can be identified by some small ribs and a hidden hinge in the front so if it didn't get latched properly, it wouldn't blow open. I tooled up and manufactured about 200 of them for MikesAfordable Model A parts supplier out of Georgia. He may still have pics of them in his catalog.
Jim Huseby is offline   Reply With Quote
Old 12-28-2015, 10:27 AM   #3
denis4x4
denis4x4's Avatar
Here's mine...a $20 tool box and some 1/4" X 2" strap.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-28-2015, 10:27 AM   #4
Y-Blockhead
Y-Blockhead's Avatar
I have the tool box sold by Mike's. http://www.mikes-afordable.com/product/T1005.html I think it looks better than the square box because it blends in with the front end. I carry my jack, some tools and other items in it. The thing I don't like about it is since it is hinged at the front if you pull the lid toward the front of the car hard enough you can open it. (Effectively bending the lid.) But I suppose if someone want to get in bad enough they could get into almost anything...
Old 12-28-2015, 10:35 AM   #5
C26Pinelake
I ordered two from Mikes and returned them as I was not satisfied with the quality. They were somewhat flimsy and looked home made! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-28-2015, 10:46 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I'm surprised no one has made a tool box that fits under the running board. It would slide out and only need to be a couple inches thick to hold a lot of tools. It would be completely out of the way of the spare tire and hand cranking the engine.
Old 12-28-2015, 11:16 AM   #7
Houdini
Houdini's Avatar
inex01,
How does the toolbox you have attach. Does it come with some type of saddle clamps that slip over the bumper brackets, or do you have to drill into them to provide a mount?
How do others support a toolbox, with clamps or do you drill and bolt on brackets? the steel on the bumper brackets is very hard to drill through.
Houdini is offline   Reply With Quote
Old 12-28-2015, 11:29 AM   #8
katy
katy's Avatar
The answer can be found on page 170 of Bratton's catalogue.
Old 12-28-2015, 12:17 PM   #9
DougVieyra
DougVieyra's Avatar
The square box tool box is MUCH larger than the 'contoured' (and more aesthetically pleasing) box sold by Mike's. In wanting to Keep my '28 Phaeton as stock as possible, I chose Mike's 'Contoured' box for it's looks, even though it holds much less tools and supplies than does the square box one.
On the other hand for my 1931 Coupe, built up as a daily driver 'Touring A', I was less concerned about original appearances. So for that car I installed the much larger capacity Box type. I have had this larger square box in service for over thirty years, and I LOVE it. With careful packing, it holds a huge assortment of items. It was especially useful when I drove from California to Alaska and back. I believe that these type of front-mounted tool boxes are still available at some of the Parts Suppliers.
Additionally, the square box that fits snuggly behind the front bumper, makes an excellent sitting chair for frequent 'fireside chats', as well as a handy shelf to set stuff on while parked.
So having and using both types of boxes, if I had to choose only one - it would be the square box. Once you get past the fact that it does look like an 'after thought', it is infinitely more useful.
P.S. - Do be mindful, that when you install either box, you lose the ability to access your crank hole, and thereby you lose the ability to use a hand crank to turn over your engine - for timing, starting, etc.
- Doug Vieyra, Eureka, California
DougVieyra is offline   Reply With Quote
Old 12-28-2015, 12:54 PM   #10
Tom Wesenberg
I find all the tools I need to carry fit under the front seat, as well as the spare parts, such as coil, and distributor. If you don't want to lift the seat for the tools, just pack them into an old suitcase, and that way they can be carried to your friend's car being worked on, or to another car you might drive.
Old 12-28-2015, 07:34 PM   #11
Jwilli
Jwilli's Avatar
Does not meet the approval of the purist, but it serves the purpose.
Jwilli is offline   Reply With Quote
Old 12-28-2015, 08:02 PM   #12
armchair67
I have the "Basement" in my 31 Tudor and love it. I am able to carry tools, extra oil, repair manuals, tools, etc.
armchair67 is offline   Reply With Quote
Old 12-28-2015, 10:21 PM   #13
bettlesr
bettlesr's Avatar
I have the contoured tool box and I think it looks great. Most people don't even notice it. It will hold a gallon bottle of antifreeze , a couple bottles of oil and a spare distributor. (Just in case the electronics one goes south). Keep a lot of tools in it also. I rekeyed the lock so the same key fits all the locks on the car. My hot water heater takes up about 1/2 the space under the seat.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 12-28-2015, 11:23 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Purists don't approve of any tool box.
Old 12-29-2015, 12:08 AM   #15
1927reocpe
1927reocpe's Avatar
( Until they break down and need some tools)
1927reocpe is offline   Reply With Quote
Old 12-29-2015, 12:27 AM   #16
Mike V. Florida
If built right they don't break down.
Old 12-29-2015, 02:17 AM   #17
DougVieyra
DougVieyra's Avatar
Mike: "If built right they don't break down."
So Mike, is that why every dealership had a 'Repair Shop', which provided much, if not most, of their 'bottom-line' income?
Even 'Perfection' has a bad day from time to time.
Old 12-29-2015, 03:21 AM   #18
Mike V. Florida
You did see the grinning smiley faces after what I wrote right?
Old 12-29-2015, 05:20 AM   #19
inex01
inex01's Avatar
That is a super idea!
Chuck McDonald,
Member of AACA, Model A Club, NRA
inex01 is offline   Reply With Quote
Old 12-29-2015, 06:39 AM   #20
apbright
apbright's Avatar
I have used the contoured box for about two years, bought from Snyder's. I do find it useful for basic tools, extra oil, and the gas filler extension neck. However, it does tend to fall open while I'm driving, and the paint finish went 'cloudy,' requiring some touch-up polish. I have considered changing to the square-type.
apbright is offline   Reply With Quote
