12-27-2015, 07:59 PM | #1 |
1913 crack in block
I found a crack in the block at the manufacture stamp on the right side between 3 and 4 cylinder. I hear there is a repair that can be done without taking engine out/apart. But I rather have it looked at by someone who is familiar with block repair. Any suggestions would be helpfull. Also -anyone know of available blocks?
12-27-2015, 08:28 PM | #2 |
Re: 1913 crack in block
Stitch welding is a good process and can be done in the car. You drill a hole in the start of
the crack and tap it then you thread in a special insert, you keep drilling one hole next to the other overlapping each one. Its a good permanent repair. Google the process. Anther quick method you can do yourself is using J.B. Weld. You grind the crack in a V and fill it with the J.B. Weld. Sometimes this can be permanent and sometimes you will have to redo it in 5 or 10 yrs. My 2 cents..... |
12-27-2015, 08:39 PM | #3 |
Give Frank Casey a call been doing stitching since 1967. Great work,once done and painted you can not see were he worked on it.He also will magna flux
Ph#508-865-6613 |
12-27-2015, 08:40 PM | #4 |
Thanks for the feed back I have heard of the stitch process and JB weld being used. what does this type of repairing do to the value when selling ?
12-27-2015, 08:54 PM | #5 |
The value will be much more than a cracked block.
12-28-2015, 07:59 AM | #6 |
Just Passin' Thru.....Slowly! Last edited by tinman080; 12-28-2015 at 08:07 AM. Reason: more info |
12-29-2015, 08:54 AM | #7 |
Thank you for that information. I agree - however there4 will be someone out there down playing the value. If I choose to sell after the repair I will tell the buyer of the repair
Thanks |
01-14-2016, 08:03 PM | #8 |
This is a cold stitching job I had done by Frank Casey. The block had four cracks.
