Old 12-27-2015, 02:28 PM   #1
Will N
Will N's Avatar
Default swedging studs
What do you guys use to back the new stud on the press when you're swedging them in place?
Will N is offline   Reply With Quote
Old 12-27-2015, 03:22 PM   #2
Kevin in NJ
Default Re: swedging studs
Something strong enough to take the 30 tons of force needed.
My stud setting device is a 1/2 steel plate with a cut down section of a pin like used for the hinges on heavy equipment. I welded a hollow round and put the pin in it. I needed to cut the pin with a cut off wheel cause it did not like the hack saw.
You can see the copy of the swage tool. It was copied from an era tool that I bought from the guy who just had a few copies made. It is hardened. You see my rendition of the holder made from the scrap I had laying around.
I need to point out this picture if from before I cut the pin down to size.
Kevin in NJ is offline   Reply With Quote
Old 12-27-2015, 03:34 PM   #3
ericr
ericr's Avatar
it would be great if someone would produce a design that would facilitate doing this though the problem is it would be so expensive.
ericr is offline   Reply With Quote
Old 12-27-2015, 04:48 PM   #4
ericr
ericr's Avatar
Originally Posted by 1930 coupe View Post
If you do not have a press, this will also work.
where do you get one?
Old 12-27-2015, 05:03 PM   #5
Kevin in NJ
Just for a cost reference.
I paid $125 12 years ago for the copy of the hardened swege. I made my own stand. I know I priced the raw materials and found I would pay like $60 for the piece metal (I think 4140). Then I would have to machine it and get it hardened properly.
So my take is it would likely cost $300 to $400 to begin to make it worth someones time to make the copy of the original design. I tend to value my time higher, but even at $250 how many would cough up the money?
Old 12-27-2015, 06:02 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Don Turley made one that he sold. Still was over the $400 range. A value if you have many sets to do, ...not so much for those who have one or two sets to do.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-28-2015, 04:18 PM   #7
Will N
Will N's Avatar
So from the pictures, it appears that the underside support is on the head of the stud only, and does not spread out onto the flange of the hub at all.
Old 12-28-2015, 04:58 PM   #8
MAG
MAG's Avatar
This one was easy to build and works well.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
