Old 12-26-2015, 08:20 AM   #1
mshmodela
mshmodela's Avatar
Default New metal.
http://m.phys.org/news/2015-12-excep...ght-metal.html
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 12-26-2015, 09:05 AM   #2
mhsprecher
mhsprecher's Avatar
Default Re: New metal.
Thanks for posting. Very interesting.
Henry Ford did a lot of early research and use of vanadium steel in the Model T.
mhsprecher is offline   Reply With Quote
Old 12-26-2015, 11:52 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Anyone know what alloy BRIVADIUM steel is? It's used for sleeves on Old Jaguars & is almost indestructible, even when a piston seizes! On HIGH mileage cars, there's NEVER a ridge! Its' downside is that it glazes over, like GLASS, & doesn't have enough friction to seat in the rings properly.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-26-2015, 04:15 PM   #4
Brian T
Brian T's Avatar
Hello Bill,
Curiosity got the better of me, I had worked on Jags but had no factory training, moved on to easier pickings, found this on Google.
I require the Rockwell or Vickers hardness of Brivadium & Brimol
metals patented by the Bristol Aircraft Company and used for aircraft
& motor engines by several manufacturers in the 1940's & 50's. The
material is an austenitic stainless steel, the Brimol being
centrifugally cast.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 12-26-2015, 04:59 PM   #5
BILL WILLIAMSON
Originally Posted by Brian T View Post
Hello Bill,
centrifugally cast.
Thanks, Brian,
Old Jags were OIL GUZZLERS ! We had to plug the rod squirt hole, just below the piston skirt. There's no oil ring that will scrape down that much oil ! We finished it with Grants' steel rings & the oil consumption was considerably BETTER.
Bill W.
Old 12-26-2015, 06:01 PM   #6
katy
katy's Avatar
The trouble I've seen with magnesium is that it burns. I've seen ladders made of magnesium burn and also an over the snow vehicle (Trackmaster) that was made of magnesium, burn up.
Old 12-27-2015, 12:05 AM   #7
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
VW engines
Old 12-27-2015, 06:22 AM   #8
updraught
updraught's Avatar
In the last, around 5 years or so, cars have been built with a harder steel which has resulted in better crash ratings from what I understand.
Perhaps it is this:
http://www.worldautosteel.org/why-st...ety-and-steel/
There is an interesting picture of the different steels used in the crash zones here.
http://www.popularmechanics.com/cars...been-17194116/
updraught is offline   Reply With Quote
Old 12-27-2015, 07:43 AM   #9
BILL WILLIAMSON
You're SO RIGHT, Katy,
That's why our wheels are no longer MAGNESIUM, they're ALUJIMUM!
During WWll, Chief worked at Basic Magnesium Inc, a foundry in Henderson, Nevada, & showed me how magnesium filings would BURN with a bright white light. He also brought me small castings, made to test metal quality. One looked like a 6 cylinder distributor cap. We thought it would be FUN to paint it BLACK & put it on someones' car SEE, it's all Chiefs' fault that I'm a HECKLER!
Chief's Son
