Old 12-23-2015, 10:51 PM   #1
duke36
Default Pot metal Carb. cleaner
Any recommendations for a carb. cleaner solution for the pot metal (tillitson style carbs) ?
Prefer not to bead blast as suggested in some threads.
Thanks.
duke36 is offline   Reply With Quote
Old 12-23-2015, 11:12 PM   #2
larrys40
Default Re: Pot metal Carb. cleaner
Napa has a good 1- gallon carb cleaner can with a dunkable strainer . I can't remember the solution but it works well . I use it often on v8 carbs and jets and small carb parts
You can get it at napa
Larry
larrys40 is offline   Reply With Quote
Old 12-24-2015, 01:13 AM   #3
Brian T
Brian T's Avatar
Rip,
If you are trying to remove that orange color that looks like stain then it will not come off, it was a process applied used as an anti corrosion coating, it can be reapplied but is somewhat spendy for the chemicals.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 12-24-2015, 01:50 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I've had good success by soaking them in T.S.P. & HOT water.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-24-2015, 11:28 AM   #5
captndan
captndan's Avatar
Bill W.
YES THIS! And use the real TSP not the phony kind.
captndan is offline   Reply With Quote
Old 12-24-2015, 12:14 PM   #6
Fred K-OR
Fred K-OR's Avatar
Larry
I used this stuff to clean my distributor and it worked well. But it is a little spendy like about $25 per gallon.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-24-2015, 12:40 PM   #7
BILL WILLIAMSON
At the Dealership, after soakin' a carb in Bendix Cleaner, I'd give it a dip in the CAUSTIC Hot Tank & it'd FOAM & FIZZ I "think" that was a help in cleaning out the passages
Bill W.
Old 12-24-2015, 12:58 PM   #8
ModAfan
ModAfan's Avatar
"I used this stuff to clean my distributor and it worked well. But it is a little spendy like about $25 per gallon. "
I bought the can of Gunk in the photo about 15 years ago to clean motorcycle carburetors. It still works just fine.
(I have no idea why the photo fell over on its side.)
ModAfan is offline   Reply With Quote
Old 12-24-2015, 02:19 PM   #9
1930artdeco
1930artdeco's Avatar
ModAfan, to much Lager?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-24-2015, 03:02 PM   #10
Merc Cruzer
Merc Cruzer's Avatar
Larry
Picture of the can....worked great on my 53' Merc Carb.
Merc Cruzer is offline   Reply With Quote
Old 12-24-2015, 04:13 PM   #11
62pan
I just did a Winfield carb with a 50/50 mix of PineSol and water in an old crock pot. Left it cook for a few hours and then scrubed it with a toothbrush. Looks like new.
62pan is offline   Reply With Quote
Old 12-24-2015, 06:09 PM   #12
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
Ok Bill what is T S P , as in your cleaning solution? I hope this is not joke, but if it is you got the old plow boy. We dont get to town much, But I got an old crock pot for cooking car parts in and I bet they will come out finger licken good Don
Indiana A. Lover is offline   Reply With Quote
Old 12-24-2015, 07:41 PM   #13
Brian in Wheeling
Brian in Wheeling's Avatar
That would be Tri-Sodium Phosphate. TSP.
Brian W.
Brian in Wheeling is offline   Reply With Quote
Old 12-24-2015, 07:43 PM   #14
1930artdeco
Indiana A Lover
Tri
Sodium
Phosphate
Mike
1957 Country Sedan
Old 12-24-2015, 09:01 PM   #15
Indiana A. Lover
Thank you for telling me the truth on this. Now oh wise men from a far, where might a wondering model A lover find such a fine product? I wait with Millers in hand and await your wisdom. AS always setting in AWE of allthings Model A. Good nite I hope the best for you all in the next year. Don south of Chicago and waiting for orders.
Old 12-24-2015, 10:03 PM   #16
ian Simpson
I get my TSP from a local paint store. It is used to wash walls prior to painting.
It also works well in removing grease from the garage floo
ian Simpson is offline   Reply With Quote
Old 12-25-2015, 01:36 AM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
I found some of the real TSP at "Home Depot".
Old 12-25-2015, 02:21 AM   #18
Indiana A. Lover
Thank you all and to all a good night. Sleep tight. Don
Old 12-25-2015, 01:49 PM   #19
Tomy Turbos
A couple-few comments to add:
1. The Gunk and Napa stuff are identical to one another.
2. On these early Carbs you have to be careful not to forget them for months. A longer soak can cause more harm than help.
3. For exterior/cosmetic purposes, a ride on the Wire Wheel is preferable to bead-blasting.
4. On ANY antique part it is preferable to start with the most benign process, such as Bill's TSP solution. If it doesn't work you'll still have the part!
5. Adding to the TSP I suggest the following:
a. Use Distilled or demineralized water.
b. A couple of drops of Dawn do well to keep whatever oily substances you may be removing under control. This aids in removing the part from its Bath.
c. Arm&Hammer 'Super Washing Soda' is a a great additive to the TSP Solution. (See also 'electrolytic rust removal'.) Works well on your laundry too!
6. Kerosene and/or Diesel Fuel do quite well at dissolving the gasoline varnish and re-liquefying whatever crystalline substance gas becomes if left long enough to petrify. Unsurprisingly, Kero is the primary ingredient to many --if not most-- of the 'special formula' products sold for this type of task.
7. Lastly, avoid at all costs ANY product containing MEK (methyl-ethyl Ketone).
8. I know this is far more than a few comments and that #7 above is NOT 'lastly' after all. But I opted to know the stuff above rather than learning to count.
There are only two kinds of cars: Those that need fixed and those which are going to.
Tomy Turbos is offline   Reply With Quote
Old 12-25-2015, 07:52 PM   #20
Indiana A. Lover
Tomy Thank you for all the help. I wrote your post out and will post it on my wall in the shop. Don
