Old 12-18-2015, 09:50 PM   #1
Larry Jenkins
Default Which type of 6" H&L discs for my rusty frame?
Just flipped the frame over. The underside is a little rusty and a little rough.
I am looking for a flexible; hook and loop 6" sanding pad for my 6" Porter Cable sander to remove the bad stuff.
Now.. Who makes a good brand of 5" discs made for sanding metal?
Is Silicon Carbide the type of sanding media I should use? 60 or 80 grit?
Would appreciate any advice and/or recommendations to make my frame look purdy..
My elbows are all greased up..
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-19-2015, 12:12 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Which type of 6" H&L discs for my rusty frame?
I would sandblast the frame. That way you'll get the rust out of the pits, and it will be easier, as you might be paying someone else to do the work.
I'm also wondering about good sanding belts, as I just used my 3" x 21" belt sander to sand down a small trailer axle and the snow plow on my Cub Cadet, and the belts didn't last too long. I don't have hook and loop, but also have a rotary sander, and would like to know about quality sanding belts and discs.
Old 12-19-2015, 12:24 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Even a knotted wire wheel would work.
Old 12-19-2015, 12:31 AM   #4
Larry Jenkins
Thanks Tom..
I can't do the sandblasting, for transportation to and from reasons, not to mention the pennies.. The top of the frame turned out well. I used Methaline Chloride and a variety of scrapers to prepare the top for paint. Then flipped the frame.
So, now like you, I am searching for a good way.
Larry
Old 12-19-2015, 12:42 AM   #5
Tom Wesenberg
You can sand a lot of the rust off, then go back over it with a spot blaster from Harbor Freight for under $20. A 40 pound bag of Black Beauty is about $7 at Menards. Hopefully you already have an air compressor.
Old 12-19-2015, 08:14 AM   #6
Big hammer
I spent 15 hours cleaning the top,sides,bottom of frame rails with sanding discs
I stood back and looked at my progress, what about inside the rails,what about
the cross members? I ended up having it chemically cleaned for 60$
It looked like new when I picked it up!! Unless your only transportation is a bike,
You can get the frame to be sand blasted, chemically cleaned. Ask a friend,coworker,
old guy down the street. Pickup,station wagon,suv with a rack on top? Good luck getting
all the rust out of the pits by hand.
Old 12-19-2015, 09:01 AM   #7
Tim B.
Lots of nooks and crannies on the inside of the frame to reach. Mike V's suggestion allows for flexible access to difficult areas without damaging your sander's pad and wasting sandpaper since you won't be flat sanding. An inexpensive 4" angle grinder using assorted knotted wire wheel shapes (instead of the disc) and an electric drill with assorted smaller wire wheel shapes and extensions will get you into most areas and will leave the metal with a clean burnished surface. Tim
Tim B. is offline   Reply With Quote
Old 12-19-2015, 10:38 AM   #8
wrndln
I sandblast every frame I have used on my restorations. They turn out great. The slightly rough metal after sandblasting leaved an excellent surface for epoxy primer like PPG DP 90 to bond to. Sandblasting gets into ALL the nooks and crannies in a frame. Many years back, I had some items dipped to remove the rust. The items looked very nice when I got them back. However, some of the parts that had were not one piece, i.e. front and rear hubs/drums seeped a whitish material similar to what forms around battery terminals for years afterward. I learned to NEVER have parts with areas between the asembly that can't be neutralized, dipped.
Rusty Nelson
Old 12-19-2015, 11:32 AM   #9
Mitch//pa
Originally Posted by Larry Jenkins View Post
Thanks Tom..
Larry
Don't skimp
I echo Toms sand blasting suggestion.....to many nooks and crannies to fight with by hand..
Old 12-19-2015, 03:47 PM   #10
Larry Jenkins
Originally Posted by Mitch//pa View Post
Don't skimp
Quality, not cost. There are good ways to do quality work without a lot of pennies.
Yeah, ya got me..
Larry
Old 12-19-2015, 03:54 PM   #11
Tom Wesenberg
Also, those red pressure sandblasting pots are more efficient than the syphon style sandblasters. I have syphon, hand held spot blaster, and the 50 pound pressure pot style. The pressure tank style doesn't cost much from Harbor Freight and it works well. To save money right from the start buy a carbide tip, so you don't have to buy lots of the cheaper tips.
Old 12-19-2015, 07:07 PM   #12
Mitch//pa
Yeah, ya got me..
Larry
If you want quality sand blast it
Old 12-19-2015, 09:10 PM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
You can get them at just about any paint and body suppiy store or maybe even a welding supply store. Never tried the welding supply store but it seems reasonable that they would have them. In my opinion the flap wheels do not work very well or that has been my experience.
Marvin/TN is offline   Reply With Quote
Old 12-20-2015, 03:52 PM   #14
Marvin/TN
There are people that will come to your house and sand blast. One type uses water and sand. When I first heard of the water/sand process I thought the water might make the metal rust but some how it doesn't. I friend had that done in in his driveway for the sheet metal on his car.
Old 12-20-2015, 04:05 PM   #15
C26Pinelake
Thanks Tom..
Larry
Possibly you should say, I can't afford not too. Too important a stage to start cutting pennies! Quite often good enough is not good enough! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-21-2015, 08:39 AM   #16
mramc1
mramc1's Avatar
Have the frame sand blasted. You'll spend more in sand paper costs than the cost to blast the frame. I had my last A frame blasted and it cost me $90.
Josh Quick
Quick Speed Shop
"6.50 rubber really gives you the old dig when you need it!"
mramc1 is offline   Reply With Quote
Old 12-21-2015, 12:14 PM   #17
Marvin/TN
If you don't have a means to haul it some where you can always rent a U-Haul if you can't get a friend with a pick up or trailer to do it for you.
Old 12-21-2015, 01:05 PM   #18
Tom Wesenberg
I used a roof rack on top of my VW Rabbit to haul home a Model A frame with the tranny and rear end still in it.
A bare frame doesn't weigh much and can easily be hauled on top of the car.
Old 12-21-2015, 02:27 PM   #19
Mitch//pa
I would love to have seen that any pics
Old 12-21-2015, 03:50 PM   #20
pgerhardt
pgerhardt's Avatar
If you have to do it by hand use 4" angle grinder and one of these:
pgerhardt is offline   Reply With Quote
