12-16-2015, 12:42 PM | #1 |
temperature gauge for 1933
Do many of owner install a temperature gauge in your cars? If so are there any out there that can fit into the 1933 instrument cluster, Like in the place of the non working fuel gauge?
12-16-2015, 01:25 PM | #2 |
Re: temperature gauge for 1933
There is a duel Temp and fuel; accessory you can get ,but most run one under the dash ,Ted
12-16-2015, 01:57 PM | #3 |
My 36 has a split temp and gas gauge in the dash. It is a nice looking gauge.
If I ay, I would like to ask you about your tires n wheels. I love the way your car sits. Did you use a dropped axle ? I sent you a message but don't know if you got it. Thanks Pat |
12-16-2015, 02:09 PM | #4 | |
Hope my rear shocks are not bad that is why it looks dropped Axel? Thanks for your positive comment. I greatly appreciate it. |
12-16-2015, 02:36 PM | #5 |
In cars up to 1934 did they determine their car is overheating? Was it because the radiator overflow kept loosing coolant?
12-16-2015, 02:53 PM | #6 |
There is a Factory duel Temp and fuel gauge ; |
12-16-2015, 02:57 PM | #7 |
I think there was a dual guage for 34 on the swap meet side last week or so, not sure if it sold? Seems the guy was asking $275 if memory serves me right
12-16-2015, 04:12 PM | #8 |
Bad shocks will not change the stance of the car, the spring does. Repair the gas gauge for better driving and you would have to change the LH water pump to a 35 or 36 to get a point where an aftermarket temperature gauge with a bourdon tube could attach. The duel fuel temperature gauges are rare and $$$ . You can get a nice, accurate Stewart Warner gauge (non electric) for a LOT less.
12-16-2015, 04:18 PM | #9 |
12-16-2015, 05:34 PM | #10 |
I have a 1933/34 dual Fuel Temperature gauge in my car. It works but is not accurate -It reads outside normal range hot at 190F. I have tried the alternate ice and boiling water baths to try and work out any bubbles in it but still reads high. Next year once the silly season is over I will need to get it recalibrated (which I think equals rebuilt!) . I did sent a message to Morris gauges who contribute on this forum if they could recalibrate it but haven't heard back yet. I'm told there are others that will work on them -Karl
12-16-2015, 08:24 PM | #11 |
Karl, there is an instrument company here in Melbourne who I believe could repair your Ford King Seeley temp gauge. Howard Instruments in West Heidelberg. That's a bit closer than the USA. Regards, Kevin.
12-16-2015, 08:32 PM | #12 |
12-16-2015, 09:52 PM | #13 |
12-16-2015, 10:13 PM | #14 |
Kevin Spoke to Howard gauges they say they can't get the red fluid for the temp gauges any more I will try and PM Morris gauges -Karl
12-16-2015, 10:22 PM | #15 |
Believe it is some environmental issue on the red fluid.
12-17-2015, 01:03 AM | #16 |
This is a stock 33-34 dual temp .
08-23-2021, 11:45 AM | #17 |
Any idea where to get a replacement gas gauge tube with attached copper tubing and fluid for a 1934 fuel/temperature gauge?
08-23-2021, 04:24 PM | #18 |
Hi. John rennerscorner.com have the gas gauge parts.
Phil. |
08-23-2021, 06:28 PM | #19 | |
highbeams |
08-25-2021, 03:21 AM | #20 |
Never found anyone else as I stopped looking -My one burped one day as I was driving along- I actually saw the bubble pass through the red liquid and now it reads perfectly acurately
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
