Old 10-23-2010, 06:11 AM   #1
lasermangene
lasermangene's Avatar
Default 1931 Ford Tudor
I would like to know if I could use a 2 pice distributor shaft to replace the long one pice that is being used now?
lasermangene is offline   Reply With Quote
Old 10-23-2010, 07:04 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 1931 Ford Tudor
I believe that's what it came with originally. Others will surely chime in if I'm wrong.
Paul in CT
Old 10-23-2010, 07:09 AM   #3
lasermangene
Thanks flamingo I have heard that but wanted to make sure just getting started on this have replaced the wiring so far again thanks for the info
Old 10-23-2010, 08:11 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, for sure you want to use the 2 piece, which is the correct and original style. Check the fit of the blade and notch on the new two piece shafts. I've had to file the notch very slightly to get them to fit together.
I haven't rebuilt a distributor for a couple years, but so far I've never had to drill or ream the bushings. I bought the shaft and bushings from Bratton's and after installing the new bushings I chuck the new shaft in my lathe or drill press and polish it using fine crocus cloth. I then wipe it clean and oil it and still using the lathe or drill press, I run it in and out of the distributor body a few times until it turns easily. I then clean out the housing and shaft with a nylon bottle brush and gasoline.
I then apply Mystik JT-6 High Temp grease in the housing along with some oil. Then install the shaft and finish the rebuild. By burnishing in the new shaft this way I get a very precision fit.
Be sure to use a very fine stranded wire for the lower plate and position the terminal so it won't touch the spring or distributor housing. Marco's website has a good picture showing how the terminal should be positioned.
REMEMBER TO OIL THE DISTRIBUTOR every oil change.
