Old 12-07-2015, 11:02 AM   #1
wbs
Default finding neutral in a different way
hello- not much luck using the conventional diagr for setting neut---i want to use a more real time approach----with rear jacked up , engine running , i want to push down on slow speed pedal til wheels go from fast to slow and then adjust the pedal to cam screw clk wise til it touches cam.
my ques is : which pedal position best defines neut, the last of high or the start of slow? i'm told by experienced people that there is no pedal posn. btween at which the wheels will stop turnining all together.
thank you---i know most people use the diagr method but i want ton visualize the affect of the screw position as its being adjusted
wbs is offline   Reply With Quote
