#1 |
Okay I am new to Model A's and need help. I want to replace the doors on my 28, how do remove the hinge screws? Someone has already buggered up the slots in the screw heads a bit. I have tried to remove them with a screwdriver but had no luck.
#2 |
Using an automatic center punch carefully punch the center of each damaged head.
Then using a left handed drill bit drill out the bolt then insert an easy out to remove bolt. If your lucky the left handed drilling will spin the bolt out. All of these tools can be bought at harbor freight for under $20.00
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#3 |
Weld a nut to the screw head . Heat breaks the corrosion . Also your favorite penetrating oil helps. Let the weld cool completely before wrenching on the nut. This is on a non painted car of course .
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom |
#4 |
I use an impact screwdriver. It comes with different sized bits, and one hammers on it while turning in the remove direction. It works wonders.
http://tinyurl.com/pyxvbje |
#5 |
Then weld a nut to the washer . Try to turn the nut almost immediately while it is still hot, but not hot enough to break off the weld, , just wait a few seconds . |
