11-28-2015, 04:52 PM | #1 |
Thank you Mitch//pa
Your tip,hint,trick helped me troubleshoot an electric problem for a disabled veterans truck(not an A) His battery would be dead after a few days. I remove the battery cable an used a test probe between them and it light up. After removing the wires from the alternator, the test light went out. Installed a fresh alternator and problem solved. I thank you and the disabled vet thanks you!! A
11-28-2015, 06:09 PM | #2 | |
Re: Thank you Mitch//pa
OH, an after thought, many times when an alternator has a bad diode, that can draw a battery down, it develops a sound, like a BAD BEARING ! SA Dad
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 11-28-2015 at 06:45 PM. |
11-28-2015, 06:43 PM | #3 | |
Thanks |
11-28-2015, 09:45 PM | #4 |
11-29-2015, 07:19 AM | #5 |
i still have that first test light pop bought me
the deluxe edition Last edited by Mitch//pa; 11-29-2015 at 07:51 AM. |
11-29-2015, 09:22 AM | #6 | |
Dad
11-29-2015, 09:54 AM | #7 |
Mitch,
that thing belongs in a museum...........................! |
11-29-2015, 10:39 AM | #8 |
