#1 |
I am putting new running boards from Snyders on a 28 tudor. Looks like the trim hooks over the top and then I have to roll the bottom under to hold them in place. How much do I roll under? Just the ends or the full length?
Jeff |
#2 |
The full length
#3 |
Whats the best way to bend it?
#4 |
I use a brake to get the initial bend then two blocks of wood and a couple C clamps
#5 |
Lay the board upside down on a flat surface to support upward pressure on the trim, use a hard flat wooden mallet to fold the trim tight to the metal board. If you do not get the trim tight it will rattle. I assume your trim is Zink like the original. Using a wooden mallet will not leave any marks on the Zink.
Ron |
#6 |
