Old 10-21-2010, 02:00 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default A handy tool to help with stuck motors
This is a tool I just got done making to help with stuck engines and to use for turning the engine during assembly when rebuilding. I used my angle grinder to cut the helix of a broken starter drive about 1/8" beyond the pinion. I then welded the helix and pinion to a piece of 5/8" steel shaft, slipped on a thick washer, greased it and slipped it through a broken end plate I'd saved. I then slipped on a large nut and welded that to the shaft. The end plate just had a little of the alingment ring broken off, but I don't like broken parts on a good rebuilt starter.
By installing this in place of the starter I can use a large wrench to bump the flywheel back and forth on a stuck engine, or it would make turning the engine over during a rebuild a lot easier.
This is not my original idea. I saw it years ago on Jim Mason's website under "HOMEMADE TOOLS".
Old 10-21-2010, 02:20 PM   #2
joe plumber
Default Re: A handy tool to help with stuck motors
Cool tool Tom.
joe plumber is offline   Reply With Quote
Old 10-21-2010, 03:44 PM   #3
V4F
V4F's Avatar
very nice tom .................... steve
V4f
V4F is offline   Reply With Quote
Old 10-21-2010, 04:32 PM   #4
George, Iowa
George, Iowa's Avatar
This just goes to show everyone....don't throw anything away. Tom will know how to make a tool out of it. Thanks TOM! Great Idea!
George, Iowa is offline   Reply With Quote
Old 10-21-2010, 06:44 PM   #5
zzlegend
zzlegend's Avatar
Perfect Tom.
zzlegend is offline   Reply With Quote
Old 10-21-2010, 07:00 PM   #6
James Rogers
James Rogers's Avatar
If I need that when I rebuild a motor, I did something wrong, too tight. Still a good tool for engines that have sit for a long time and are stiff or stuck.
Old 10-21-2010, 08:04 PM   #7
Glenn C.
Glenn C.'s Avatar
Great idea Tom ! I will build one up for our shop.
Glenn C. is offline   Reply With Quote
Old 10-21-2010, 08:39 PM   #8
RockHillWill
RockHillWill's Avatar
Nice work Tom, and just in time. I thought I had every tool .
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 10-22-2010, 12:28 AM   #9
Russ/40
Russ/40's Avatar
Amazingly simple, and yet very powerful tool. Great idea.
Russ/40 is offline   Reply With Quote
Old 10-22-2010, 11:17 AM   #10
Ray64
Ray64's Avatar
You DA Man
Ray64 is offline   Reply With Quote
Old 10-22-2010, 12:32 PM   #11
Rich in Tucson
Rich in Tucson's Avatar
I went to look at an engine an acquaintance in DE wanted to sell. He was busy with a similar homemade tool trying to turn the engine over with about a 5 foot bar. A few seconds later, it was unstuck alright, but had a distinct "clunk" with every revolution that diminished in intensity quickly. Stuck rings, he declared.
When the head came off, there sat the top of #3 piston at the top of its bore and cleanly parted from the bottom of the piston and the rod.
Mind the force!
Rich in Tucson is offline   Reply With Quote
Old 10-22-2010, 02:33 PM   #12
Wuudie
Wuudie's Avatar
Necessity is the mother of invention- Patent it.
My Pop and uncle had an old tool they used to get stuck tractor engines free. two 12 oz bottles of Coke.
I seen them do this on an old John Deer. It was over 30 years ago, but I remember them doing this. Poured them in the oil fill, drained the pan then put oil back in and sure enough that bucket started up. Smoking, but they got em going. Has anyone heard of this???
Course- it could have been me being a youngen and my pop and uncle playing one of thier jokes on me. I remember this days specifcially cause my uncle gave me some Chewing tabacco and me getting sick.
Plus I never knew this at the time, but found out later. Pop worked at the steel mill and you never knew what type of liquid/lubricant he smuggled out of the mill in his empty bottles/lunch box. Which leads to another story of my sister in law taking a sip of brake fluid at Christmas dinner, but that was well worth it!
Wuudie is offline   Reply With Quote
Old 10-22-2010, 11:02 PM   #13
Stillrunners
Stillrunners's Avatar
cool...good job!
Stillrunners is offline   Reply With Quote
Old 10-23-2010, 06:34 AM   #14
RichPA
RichPA's Avatar
a few years ago I was at a snowmobile shop and the old timer was cleaning a gas tank with Coca Cola. He said it works on anything rusted, never tried it. I think if an engine is that stuck it should be taken apart.
RichPA is offline   Reply With Quote
Old 10-23-2010, 07:21 AM   #15
RockHillWill
Coke is a very good, quick acting solvent for tire rubber as well. I used to be involved in a motorsports activity and during a pit stop window cleaner was not always good enough as you didn't have time to sit there and scrub the windshield. I would some times just reach back and snatch a spectators coke and dump it on the windshield and off we'd go.
Old 10-23-2010, 10:10 PM   #16
Wuudie
Wuudie's Avatar
Would you buy those spectators a replacement coke you took?
Old 10-24-2010, 03:52 AM   #17
FlatheadTed
FlatheadTed's Avatar
Nice one Tom ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-24-2010, 11:51 AM   #18
Glenn C.
Glenn C.'s Avatar
Possibly one slight improvement would be to install a grease fitting on the boss side.
Still a great idea for a tool !!
Old 10-24-2010, 12:33 PM   #19
Tom Wesenberg
I gave that a lot of thought and was tempted to install a 1/4-28 zerk, but for no more revs than this tool will make I think the grease I packed it with will outlast me.
Old 08-19-2013, 11:05 AM   #20
ronn
Rich,
the force be with you......
