10-21-2010, 11:05 AM | #1 |
40 stabilizer bar
Does anyone have a photo of a stabilizer bar for a 1940 that is INSTALLED???
Confused on installation from stabilizer rod to swivel...thanks |
10-21-2010, 11:36 AM | #2 |
Re: 40 stabilizer bar
It takes a special perch bolt that will accomodate the swivel and the shock arm - somewhat hard to come by but I do happen to have a set if you are interested - PM me if so.
How you tell the perch bolts apart is by the shock mount (there are numbers on them but I never can remember one from the other) - it should be fairly obvious that way. |
10-21-2010, 12:28 PM | #3 |
Right hand perch bolt is # 01A-3032-C. LH is 01A-3033-C. Here's some pix. Sway bar will sit more level if car wasn't so low.
10-21-2010, 10:26 PM | #4 |
I installed one of those on my 39 Standard. It made a world of difference in handling.
Jim |
10-22-2010, 05:07 AM | #5 |
got my new rubber bushing and swivels from Dennis Carpenter
10-22-2010, 11:45 AM | #6 |
10-22-2010, 01:21 PM | #7 |
sweet
10-25-2010, 01:10 AM | #8 |
My 40 coupe leans like crazy when im in it; and im not that BIG!
I need to put my stabilizer back in. Thanks for the pictures, this should help me as well
Check it out! Cars: 1940 Ford Business Coupe, 1941 Ford Sedan, 1951 Cadillac CDV, 1964 Cadillac Calais |
10-25-2010, 02:35 AM | #9 |
40fordpu-
Enclosed are some pictures of a '40 swaybar on have on my '35. There are a lot of after-market swaybars on the market but you can't beat a '40-'41 for the "factory look." Last edited by flatheadfan; 04-22-2013 at 02:54 PM. |
