Old 11-19-2015, 04:34 PM   #1
emf
emf's Avatar
Default Two 81's on a Burns Manifold - Results
Thought you guys might like to see this. Got my Burns installed today with two Stromberg 81's. Other than playing with a return spring here and there and cleaning up the linkage, they started right up and I was flying...
It runs fine without a pump, but I was at 1/4 tank and ran out of gas at the carbs. The Walbro pump has a bad diaphragm, so that will need to be replaced. Like I said in another thread, the piping isn't as elegant as I would like, but with the distributor in the way of just about everything, it will have to do. I'm quite pleased, it was really bolt and go...
Frank
emf is offline   Reply With Quote
