Old 11-10-2015, 01:18 PM   #1
Fillinjc
Fillinjc's Avatar
Default Another Stuck Head
Hi,
I know there are threads posted on this topic on this forum and others. Only out of frustration will I start another. Been working on removing my head off and on for several days now. Continuously spraying the studs with penetrating oil. My latest attempt has been with a jury rigged puller using some scrap channel (pic attached). I can see light under 7/8's of the head. But the stud on the front corner by the water pump isn't budging. I have rapped down on it with a brass hammer. I have tapped around the diameter with a punch. Would a puller from the Model A suppliers do more than my makeshift one? Any other suggestions? I can't see the rope in the cylinder trick applying more pressure than I already am.
Thanks,
Jerry
Fillinjc is offline   Reply With Quote
Old 11-10-2015, 01:41 PM   #2
30ccpickup
30ccpickup's Avatar
Default Re: Another Stuck Head
Try removing some of the looser studs with a jam nut (double nuts), before pulling.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 11-10-2015, 01:49 PM   #3
rf900rkw
On the old Jaguar XK engines the heads were always corroded to the studs. I would wind a sacrificial nut onto the offending stud, put an air chisel with a wide flat bit against a flank of the nut, and buzz the crap out of the stud. You are pushing the stud sideways in the head hole. Try different angles and you will eventually find one where all that corrosion goo comes oozing up and out like a play-doh press. Hopefully this technique can be adapted to the A engine.
rf900rkw is offline   Reply With Quote
Old 11-10-2015, 02:55 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Those front two bolts are usually the worst for sticking, so I made this tool to help put a lot of lifting pressure on the studs.
https://www.fordbarn.com/forum/showth...ade+tools+head
I would start by installing a nut loosely on each stud, then rattle it from the side with an air hammer. Spray Kroil on the stud first.
Old 11-10-2015, 03:31 PM   #5
H. L. Chauvin
FWIW: Never saw a rusted Model A head or Model B head or military vehicle head that could not be lifted with "hard maple" wood wedges.
1. Start by compressing sides of head soft gasket with a large flat head screw driver making about (10) openings, (5 each side), about 2" in width. Even out openings with a putty knife.
2. Make (10) "hard maple" wood wedges, about 1-7/8" wide x 6" long with a taper starting at a sharp edge and sloping upwards to about 3/8" thickness; or 12" long sloping upwards to about 3/4" thickness.
3. Most importantly is:
A. Not how often or how hard the wedges are hit with a hammer; nor,
B. How deep the wedges are driven inwards; nor,
C. How many replacement ruined wedge have to be replaced; however,
D. Most importantly is to check "often" to insure that when lifting, the flat bottom side of the head "always" remains "perfectly parallel" to the flat top of the engine block ........ so that fixed, head bolts securely fastened to the engine block remain "perfectly parallel" to the corresponding head bolt holes in the head.
Seeing day light under 7/8's of head is a major problem in itself, thus causing severe jamming friction and resistance between rough rusted bolt shanks and rough rusted bolt holes.
H. L. Chauvin is offline   Reply With Quote
Old 11-10-2015, 04:08 PM   #6
Willie Krash
Willie Krash's Avatar
As always H.L has great advice. (always)
I used Maple blocks too. I did get a little lift on the head and would knock it back down.
I'd use the puller, knock it down, etc..etc.
Watch out for open valves on the starboard side.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 11-10-2015, 04:09 PM   #7
CarlG
CarlG's Avatar
If you can back those two front studs out, everything else goes much easier.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-10-2015, 04:26 PM   #8
Bulligen
Bulligen's Avatar
Like someone has already said the head MUST stay perfectly parallel or it will not come off. Your puller is as you can see too far towards thr front to evenly. I have taken alot of heads off and penetrating oil and patience does alot as well!
Bulligen is offline   Reply With Quote
Old 11-10-2015, 06:00 PM   #9
30coupeguy
I made the mistake of not being careful enough when using wedges and bent a valve, just like the warning above.
I learned a lot when trying to get my stuck head off. First of all, it HAS to be raised parallel to the block. If it isn',t then you HAVE to knock it back down.
That just might do the trick. There was an article in the "Restorer" around October of last year that compared the different penetrating oils. It showed the differences in foot pounds required to break loose nuts, etc. The very best was a mixture of 50% transmission oil and 50% acetone. I tried them all. It took me weeks of soaking, lifting with the head lifting tool I bought from Snyders, and hanging the d... thing (car engine and all) from a shop crane. All the time soaking the devil out of the studs. My machinist son in law came by one day and I was showing him my problem and he peeked at the my set up and said lets knock the head back parallel. Three minutes later the head was off and sitting on my bench.
burt
30coupeguy is offline   Reply With Quote
Old 11-10-2015, 06:32 PM   #10
brum1
brum1's Avatar
I have also used heat with great success with a puller in place. Oxy/Acetylene if you got it
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 11-10-2015, 08:55 PM   #11
glenn in camino
glenn in camino's Avatar
I always use a bottle jack from the generator mount to the underside of the front of the head. Jacking up the front will also loosen the rest of the head so you can get a large screw driver under the rear and pry it loose. Works every time.
glenn in camino is offline   Reply With Quote
Old 11-10-2015, 09:09 PM   #12
stewwolfe
stewwolfe's Avatar
A member of our club made an auxiliary head puller. It is an angle iron that was drilled to fit the water pump mounting holes with two studs mounted through the angle that screw down onto the long studs going through the water jacket. It works well. If you are interested let me know and I'll photograph it and post a photo.
Sent from my iPad using Tapatalk
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 11-10-2015, 09:39 PM   #13
Tom Wesenberg
I can picture it because right after I spent many hours making mine, I thought I should have just made one out of heavy angle iron.
It would still be nice to see a picture of it.
Old 11-10-2015, 09:41 PM   #14
stewwolfe
stewwolfe's Avatar
I'll take a picture in the morning and post it. I will tell you that it isn't as nice looking as yours.
'31 40B
'31 68C
Old 11-11-2015, 07:11 AM   #15
stewwolfe
stewwolfe's Avatar
'31 40B
'31 68C
Old 11-11-2015, 07:18 AM   #16
stewwolfe
stewwolfe's Avatar
Unfortunately Tapatalk won't let me write in the same area as I post photos. John used a 4" by 6" angle iron. The 4 holes line up with the water pump holes. When you bolt it to the head the Jack screws on the top will line up with the two long head studs that come through the water outlet. Combine it with a standard head puller, or some hardwood wedges and it will get most any stuck head off.
'31 40B
'31 68C
Old 11-11-2015, 09:14 AM   #17
Tom Wesenberg
Yep, that's exactly what I thought I should have made instead of the one I did make. Mine works great, but takes too much time to make, and a thick angle iron plate can do the same job. I would screw nuts to the end of the studs to give the bolts more surface area to push against, and to protect the stud threads.
Old 11-11-2015, 12:08 PM   #18
stewwolfe
stewwolfe's Avatar
Good idea and easy to rectify.
'31 40B
'31 68C
Old 01-12-2016, 06:29 PM   #19
jaguar6165
I've read and searched the forums and I have a couple questions as I am having issue with a stuck head. I bought a metal plate to make my own puller and have the studs marked using a new gasket, but haven't drilled it yet for the bolts. What is the best way to bust out old plugs? I figured I'd drill the holes for the studs and line it up with the hollowed plugs so I can get an accurate mark for their location in the plate.
jaguar6165 is offline   Reply With Quote
