Old 11-08-2015, 09:48 PM   #1
ford31
ford31's Avatar
Default doodlebug question
thinking about putting 5 gallon gas tank behind seat,using electric fuel pump,what preasure would be ok with the zenith carb,now does anyone have a recommend
for regulator
ford31 is offline   Reply With Quote
Old 11-08-2015, 10:20 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: doodlebug question
2 or 3 pounds pressure should be fine. I run a 12 volt Holley on a 6 volt battery, and still have to add a 3 ohm 50 watt resistor to drop the pressure and flow to what is needed. It's cheaper than a pressure regulator and it makes the pump run slower and last longer.
