Old 11-07-2015, 04:02 PM   #1
BNewman
Default Model A Engine Installation
Advice Needed !!
I have both the engine and transmission out of my '31 Victoria.
My question is what is the better way for installation:
1. Engine and transmission as a unit?
2. Transmission & bell housing first, then engine with clutch and clutch housing attached.
Thanks,
Bob
BNewman is offline   Reply With Quote
Old 11-07-2015, 04:14 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Model A Engine Installation
Originally Posted by BNewman View Post
Advice Needed !!
2. Transmission & flywheel housing first, then engine?
Thanks,
Bob
tranny,housing then engine is my preference
www.whidbeymodelaclub.com
Old 11-07-2015, 04:25 PM   #3
CarlG
CarlG's Avatar
Shouldn't the flywheel housing be attached to the engine and installed as a unit?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-07-2015, 04:28 PM   #4
Mitch//pa
yep
Old 11-07-2015, 04:33 PM   #5
Mitch//pa
here is a former post on the topic
http://fordbarn.com/forum/showthread...engine+install
Old 11-07-2015, 04:35 PM   #6
Fred K-OR
Fred K-OR's Avatar
I think you will get a number of comments both ways. But I would do your #1 option assuming you have the tools to do it that way and some help in doing it.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 11-07-2015, 05:22 PM   #7
Synchro909
Synchro909's Avatar
If you put the engine and transmission in as a unit, you have to get the torque tube shaft lined up with the universal joint for them to go together. DON"T be tempted to use your fingers to do it. When they slip together, you could lose them.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 11-07-2015, 08:27 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I prefer to install the tranny, then the engine.
Old 11-07-2015, 09:12 PM   #9
Larry Jenkins
Tom..
Can you offer some step-by-step details? When you say "engine," does that mean the flywheel, clutch plate and flywheel housing attached?
Can you even attach the tranny before dropping it in? Assembly problems?
Thank you!
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-08-2015, 03:21 AM   #10
Tom Wesenberg
Originally Posted by Larry Jenkins View Post
Tom..
Thank you!
Larry
Yes, the flywheel and flywheel housing must be installed if the engine is installed after the tranny. Be sure to set the fingers on the pressure plate while it's out, and use a clutch alignment tool to make sure the disc is centered. If the alignment tool wasn't available I've used my fingers to center the disc by going around the outer edge, and this has also worked fine for me.
Old 11-08-2015, 06:51 AM   #11
Mitch//pa
if the body is off i install them as a unit. otherwise trans first
Old 11-08-2015, 10:50 AM   #12
Larry Jenkins
Body is off; frame is bare except the motor mounts.
If so, can I drop in the whole engine with the tranny on it? Clearances; assembly problems?
Thank you Sir!
Larry
Old 11-08-2015, 11:19 AM   #13
Fred K-OR
Fred K-OR's Avatar
Thank you Sir!
Larry
This is how I did it on my huckster and it worked great. But like mentioned, look out for your fingers when putting in the u-joint.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 11-08-2015, 11:28 AM   #14
larrys40
I agree with Mitch . It is easier to get the engine in the mounts and splines line up on the clutch than it is to deal with the floppiness of the u-joint to get it in the mounts and splines if the driveshaft at the exact same time
I have done both ways and can be done either way, but for a novice I would opt to do them separately
Get a helper or two to assist you as well
Also, as Tom noted its the time to make sure the pressure plate is set up properly . See specs and procedures in les Andrews mechanical book
Larry Shepard
larrys40 is offline   Reply With Quote
Old 11-08-2015, 12:07 PM   #15
BNewman
Thanks
Old 11-08-2015, 12:08 PM   #16
BNewman
Good call. Thanks.
Old 11-08-2015, 04:52 PM   #17
Mitch//pa
Thank you Sir!
Larry
thats the way i would do it with the body off. one thing to look out for is the u-joint housing gaskets dont slide out of place. put a couple temporary bolts in the holes while mating things together
Old 11-08-2015, 07:19 PM   #18
harleytoprock
How about with body on and rear diff is out? Can motor/trans assembly be installed as unit with no problems?
harleytoprock is offline   Reply With Quote
Old 11-08-2015, 08:25 PM   #19
George Miller
George Miller's Avatar
My way also.
George Miller is offline   Reply With Quote
Old 11-08-2015, 08:31 PM   #20
glenn in camino
glenn in camino's Avatar
I always assemble everything back to. and including, the U joint, and install it all together. Get a friend to help guide it. Also you may need a frame spreader.
glenn in camino is offline   Reply With Quote
