Old 11-06-2015, 03:41 PM   #1
saabvol
Default Light in the gear indicator Ford 1956 F-line
Hello
Is there to be light in the gear dial indicator on Ford 1956 Fairlane. Fordomatic.
Regards
Mikael
saabvol is offline   Reply With Quote
Old 11-06-2015, 07:54 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: Light in the gear indicator Ford 1956 F-line
Yes, Both the '55 and '56 Fords have a bulb behind the shift indicator. To replace the bulb, reach back behind the dashboard and pull out the light bulb socket. The bulb is removed from the socket by twisting counterclockwise less than 1/4 turn and release. Pull the bulb out. Install new bulb and push the socket back into the light bracket in the back of the dashboard.
Daves55Sedan is offline   Reply With Quote
Old 11-07-2015, 01:30 AM   #3
saabvol
Thanks Dave.
Regards
Mikael
Old 11-08-2015, 04:38 AM   #4
saabvol
Hi again
I have looked but i aint able to find the lamp holder. Is it in the instrument cluster or in the dashboard?
Regards
Mikael
