Old 10-27-2015, 08:19 PM   #1
Wizard47
Wizard47's Avatar
Default 1936 5 window project: what to do?!?
Just picked this girl up. I was told it was a lot cleaner then it was when I got it. Holy crap. Roofs been cut off and then welded back on like crap. Needs all the lower patch panels but the floor is half way decent. Right cowl panel is basically all fiberglass. The amount of fiberglass on this car blows! All the fenders have filler and fiberglass around the edges. I'm stuck now cause I don't know if I should build a roadster out of it. I have the tools and skills to make all the roadster correct panels or do I sell the damn thing. I don't know. What do you guys think? I paid 3200 bucks for it. Came with a seat and headlights so at least I kinda got the hard parts to find.
Wizard47 is offline   Reply With Quote
Old 10-27-2015, 08:25 PM   #2
Heard
Heard's Avatar
Default Re: 1936 5 window project: what to do?!?
Are you sure that won't buff out??
Do I look like I have a plan B?
Heard is offline   Reply With Quote
Old 10-27-2015, 08:50 PM   #3
Charlie ny
Give Dave Kindig or Richard Rawlins a call.....it could be a feature car.
Seriously though, I see what appears to be a 21 stud motor judging by the LH water
pump peeping over the fender..could it be an LB ? If it is an LB Flathead that is in
decent shape 80% of your $3200 is covered.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 10-27-2015, 09:34 PM   #4
Wizard47
Wizard47's Avatar
Charlie ny
Damn didn't know anything about a lb flathead. No I have to look
Old 10-27-2015, 09:38 PM   #5
Wizard47
Wizard47's Avatar
Old 10-27-2015, 10:40 PM   #6
34coupe
34coupe's Avatar
3,200 for a 36 ford coupe roller is not a bad deal, if you've got the talent to make roadster panels then it should be a easy project, good luck
Wanted: 1933-34 Ford roadster project-parts anything roadster Now go out in the garage and build something !
34coupe is offline   Reply With Quote
Old 10-28-2015, 06:26 AM   #7
Tom Morookian
Tom Morookian's Avatar
Better than what I started with. I paid $2K plus $990 for delivery for a basket case with all kinds of stuff missing. Those rear fenders are wort $500 each and so is the trunk lid. If the frame is good you've still got a good deal. If the motor turns over you've got a GREAT DEAL.
Tom Morookian is offline   Reply With Quote
Old 10-28-2015, 07:32 AM   #8
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
It would make a nice vintage stock car, I built a 36 stock back in 65. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 10-28-2015, 09:12 AM   #9
Straightpipes
Straightpipes's Avatar
If you want your money back pull the engine and see if it has inserts. Sell it to these guys on the Fordbarn. Put the body on the HAMB for the hot rodders
to chew on.
Straightpipes is offline   Reply With Quote
Old 10-28-2015, 09:21 AM   #10
TagMan
I'd get rid of it ASAP !! Send it to me and I'll take it off your hands.............
TagMan is offline   Reply With Quote
Old 10-28-2015, 09:21 AM   #11
RobR'35
RobR'35's Avatar
First see if its stamped LB on the drivers side of the block,top flat of block between the head and intake manifold.
RobR'35 is offline   Reply With Quote
Old 10-28-2015, 09:25 AM   #12
RobR'35
RobR'35's Avatar
Tho not all were stamped I understand....
Old 10-28-2015, 09:47 AM   #13
SUHRsc
SUHRsc's Avatar
I just discovered this on my car.... had a couple friends confirm it looks legit.
Just showing so you know what to look for... the "L" is a bit light
-WANTED-
CYLINDER HEADS
77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS
SUHRsc is offline   Reply With Quote
Old 10-28-2015, 09:55 AM   #14
Bored&Stroked
Bored&Stroked's Avatar
Zach - I just need to point out that that darn 3/8" bolt on your intake is NOT an original Henry Ford bolt . . . now get it out of there!
Thanks for sharing the 'LB' markings picture - have never owned one myself.
Old 10-28-2015, 10:32 AM   #15
SUHRsc
SUHRsc's Avatar
How's that? ^^^^ (check photo)
-WANTED-
CYLINDER HEADS
Old 10-28-2015, 11:25 AM   #16
Bored&Stroked
Yah fixed it!
Old 10-28-2015, 03:26 PM   #17
Wizard47
Wizard47's Avatar
Looks like it's an LB motor
Old 10-28-2015, 03:30 PM   #18
JSeery
JSeery's Avatar
Now IF it's a good block you should be in business!!!
Old 10-28-2015, 05:40 PM   #19
Wizard47
Wizard47's Avatar
What do you guys think the motors worth if I don't pull the heads of and its stuck.
Old 10-28-2015, 06:25 PM   #20
Bored&Stroked
Whatever somebody is willing to gamble - and a gamble it is! Me, wouldn't give more than a $100 - unless there was a guarantee to return it if it wasn't cracked or had other issues. If a guarantee was given, then I'd probably go up to $400 or so.
