Old 10-25-2015, 06:59 PM   #1
John Walters
John Walters's Avatar
Default Leaking Oil while engine runs
Hopefully this photo is attached. I have oil leaking from a small hole in flywheel housing(?). It leaks when running but stopped when engine turned off. This car (30 pickup) has a later ('39) transmission, so I am not sure if I am looking at a 1930 portion of the transmission or the 39. Any help appreciated.
jw
John Walters is offline   Reply With Quote
Old 10-25-2015, 08:19 PM   #2
Dick Deegan
Dick Deegan's Avatar
Default Re: Leaking Oil while engine runs
I would guess that the drain tube on the rear main is wither missing or it's plugged - or the passageway that the pipe fits into is plugged.
Dick
Dick Deegan is offline   Reply With Quote
Old 10-25-2015, 08:29 PM   #3
RonC
RonC's Avatar
Rear main be have excessive clearance from wear also. Check the clearance
RonC is offline   Reply With Quote
Old 10-25-2015, 09:21 PM   #4
1955cj5
1955cj5's Avatar
This thread may help..
https://www.fordbarn.com/forum/showthread.php?t=181073
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 10-25-2015, 10:17 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
John,
Make SURE it's not GEAR OIL. A friend had his engine out 3 times, fussin' around with the rear main, BEFORE he discovered it was TRANSMISSION OIL!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-25-2015, 11:15 PM   #6
PC/SR
I have a 39 trans and the leak you see is likely from the rear bearing, but check to make sure it is engine oil, not trans oil like Bill says. Check oil level first. Recent thread on this.
PC/SR is offline   Reply With Quote
Old 10-26-2015, 12:25 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
That hole should also have a large cotter pin to shake and keep the oil and dirt from plugging the hole.
