Old 10-16-2015, 12:57 PM   #1
exoilfld
Default 47 trans removal
Does anyone know it the trans on a 47 pu, open drive shaft , can be removed without taking the engine out; is there enough room? Looks like it would be close.
exoilfld is offline   Reply With Quote
Old 10-16-2015, 04:58 PM   #2
alan
Default Re: 47 trans removal
yes you can, but be aware that it will come up thru the floor board to come out. a little hard to hold on to, remove shift handle, use a chain and a piece of heater hose 3/4", attach this to screws holding the top shift cover on the trans, this makes a really good handle
alan is offline   Reply With Quote
Old 10-17-2015, 07:45 AM   #3
exoilfld
Thanks. I never would have thought to make it come out that way. Thank you.
