Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 09-27-2015, 02:28 PM   #1
crumbaa
crumbaa's Avatar
Default 1930 cabriolet 68B door parts
City: Canton
State: IL
PARTS FOUND AT BERT'S THANKS for all the replied
I am restoring and 1930 Cabriolet (68-B) Briggs body and am missing a couple pieces for the right (passenger) side door.
One is the door latch and inside door lever assembly. I have attached a picture of the the one that was in the left side door. I need its mirror image mate for the right side. The right side latch has an outside key lock that the left side does not. If all you have is the latch part that is the part I need the most.
Second is the Metal panel that goes inside the Right side door. This is the metal panel that the inside door lever and the window regulator bolt to. I have attached a picture of the one that was in the left side door. I need its mirror image mate for right side door.
If you don't have either do you know anywhere I could look? This is not a high point car so reproduction or something that could be made to work with some lite modification would be fine too.
If it was easy everyone would be doing it
/Tony
crumbaa is offline   Reply With Quote
