Old 09-15-2015, 04:19 PM   #1
eystein
eystein's Avatar
Default Removal of flux
Any recommendations as to which solvent to use to remove solidified residues of flux from silver soldering (brazing). Most of it forms a glass like layer that will crack away when using a scraper. However, some of it is hiding in pores left behind after removing rust. I would like to use a suitable solvent and the miniature wire wheel on the dremel.
So which solvent?
eystein is offline   Reply With Quote
Old 09-15-2015, 06:26 PM   #2
harleytoprock
Default Re: Removal of flux
It's important to remove the flux as it is corrosive. However, I don't believe there is a solvent that will remove it. All you can do is chip and sand blast .
harleytoprock is offline   Reply With Quote
Old 09-15-2015, 07:01 PM   #3
Tinbasher
Tinbasher's Avatar
The best way to remove soldering flux is to use a mixture of water and baking soda. make a saturated solution and then scrub the flux with a red scotch-brite pad and the mixture. This will lift the flux and neutralize it in one go. Then rinse the clean area with clear water and dry. If your body soldering then you need to wash the area with lacquer thinners as a last step to remove the lubricant from the paddles. Then your good to prime.
John Poole
Tinbasher is offline   Reply With Quote
Old 09-15-2015, 08:23 PM   #4
harleytoprock
The flux eyestein is talking about is boric acid which turns into a glass like substance. Its very different from the flux that's used for soft soldering.
Old 09-16-2015, 12:32 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with the sandblast. That will also leave the surface better for the paint to adhere to.
Old 09-16-2015, 01:59 AM   #6
Marvin/TN
Send a message via AIM to Marvin/TN
Just go to an auto body supply store and get a mule Skinner brush. They are a 2" brush with epoxy molded in the bristles. They come with a Mandrel and brush. After you have the mandrel you can buy just the brush. Use them in 1/4" drill. Mule Skinner
is a brand name so sometimes they don't use that name. They work very well for cleaning up welds rough metal etc.
Marvin/TN is offline   Reply With Quote
Old 09-16-2015, 12:57 PM   #7
burner31
burner31's Avatar
There is a product we use on aircraft wiring that is a thread like material that wicks the flux off like magic.
I'll get the product name and repost, I have some in the garage...but damn if I can find it right now.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-16-2015, 03:12 PM   #8
Pete
So which solvent?
Be aware that using solvents to remove borax flux could result in the solvent getting in places it can not be reached to be completely neutralized.
There are chemicals that will remove the flux but you had better research that yourself.
Old 09-16-2015, 08:16 PM   #9
Tinbasher
Tinbasher's Avatar
Funny it works for me on Silver Solder.
JP
Old 09-17-2015, 02:00 AM   #10
burner31
burner31's Avatar
Quick Braid
Rosin
mfg. by
Easy Braid
Cat.No. Q-B-5AS
We use this item on military heavy's, (bombers/tankers/E-3's/E-6's) it's a flat copper like thread that comes in a little blue spool, heat the area with your solder gun touch the braid on it and it wicks the old solder and flux right off the contacts like magic, clean and ready to go again.
I'm sure there is a civilian equivalent, if not this particular product,
for sale at fine stores that sell solder and solder accessories.
Keith
Shawnee OK
'31 SW 160-B
Old 09-17-2015, 11:04 AM   #11
katy
katy's Avatar
AKA solder-wick
Old 09-17-2015, 11:08 AM   #12
MrTube
MrTube's Avatar
We use Quickbraid all the time here, it's a normal consumer product.
However, I highly doubt rosin soldering braid will do anything to a silver soldered product. You silver solder at 1400+F not 650. I think when I solder using Stay-Silv 15 I'm over 1600F. The nice thing about Stay-Silv 15 is for copper to copper joints you don't use a flux.
I've also never seen it remove flux but could be wrong there.
MrTube is offline   Reply With Quote
