09-08-2015, 07:13 PM | #1 |
how to remove tapered grease fittings
What is the best technique for removing the tapered grease fittings?
09-08-2015, 07:25 PM | #2 |
Re: how to remove tapered grease fittings
you mean original style press in? if you dont plan to reuse them locking pliers and a little twist and usually pop out.
1929 Model AA - Need long splash aprons! |
09-08-2015, 09:05 PM | #3 |
I couldn't get mine to pop out. I ended up drilling out with a tap drill for a 1/4-28 thread and tapping with a 1/4-28 tap. Installed a new fitting into the hole. So far it is working well and looks almost like it belongs there.
09-08-2015, 09:55 PM | #4 |
09-08-2015, 10:01 PM | #5 |
Why replace them? They take grease just fine with the original gun.
John |
09-09-2015, 12:02 AM | #6 |
09-09-2015, 06:44 AM | #7 |
when i restored my front end, i removed all the press in fittings with a small channel locks.. after refinishing / restoring all the parts i installed new press in style replacements...
09-09-2015, 03:40 PM | #8 |
Mitch: You didn't "restore" the originals??
Paul |
09-09-2015, 03:55 PM | #9 |
I have had good luck using a hammer and cold chisel. With light hammer taps work around the edge of the fitting and gently wedge the fitting up and out of the socket. The key word is "gentle” so you wedge the fitting up and not cut it off!!!
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-09-2015, 04:03 PM | #10 |
