Old 08-26-2015, 12:02 PM   #1
Del in NE Ohio
Del in NE Ohio's Avatar
Default Hi speed aftermarket rear end?
Went this AM to help a friend who had just removed engine and transmission from a '31 pickup. We plan to dive into the rear axle assembly tomorrow. As we discussed possibly changing the ring and pinion for a higher ratio, we decided to try to determine what rear end ratio is in the truck. So, we jacked up the truck. A complete 360 degree revolution of the rear wheel resulted in slightly less than 2 revolutions of the drive shaft. Seemed odd, so we did it again. What do we have here?
Been on meds lately, so I am reluctant to do the math. Seems like a really high rear end ratio, or am I still in a pharmaceutical fog?
Del in NE Ohio is offline   Reply With Quote
Old 08-26-2015, 12:37 PM   #2
Sparky
Sparky's Avatar
Default Re: Hi speed aftermarket rear end?
When you hold one wheel stationary don't you double the ratio through the differential? So it sounds like you have the standard 3.78:1. 3.78/2 = 1.89 which is about what you say you measured.
Sparky is offline   Reply With Quote
Old 08-26-2015, 01:12 PM   #3
Fullraceflathead
Fullraceflathead's Avatar
Yes it is doubled when turned one completed revolution with other wheel locked from moving.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 08-26-2015, 01:20 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, with one wheel turning, it will turn twice as fast, so you need to make two revolutions of the tire and count the revs of the engine. Or, an easier way is to hand crank the engine 3.78 turns and see if the rear tire makes exactly two turns.
Old 08-26-2015, 01:33 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A 3.78 ratio is a quite decent ALL AROUND RATIO. I, personally, would not change it, like, how fast do we need to go?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-26-2015, 03:13 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
My experiences is a Model-A with a high-speed Ring & Pinion greatly enhances the drivability. At minimum, we typically install a 3.54 ratio and often install the 3.27 ratio. These two ratios are good for another 4-7 MPH at cruising speed. While that does not sound like much, it takes an engine that likes 45 mph and turns it into roughly a 50 mph vehicle. Often times this is just what is needed to keep from holding-up traffic.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-26-2015, 04:44 PM   #7
BILL WILLIAMSON
GOOD point you made, Brent,
"Maybe" these inputs will help Del consider what is the best for HIS NEEDS.
3:78's are fine for ME, as I'll be mostly in Big City driving.
Bill W.
Old 08-26-2015, 05:12 PM   #8
CarlG
CarlG's Avatar
3.78 is fine by me as well. 80% of my driving is city driving as well. For the long haul open highway tours, I just slip it into overdrive, sit back and let the engine loaf!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-26-2015, 05:39 PM   #9
TinCup
TinCup's Avatar
I think for me more importantly 354 gears would take a car that likes to run 45MPH and reduce stress on the engine by reducing rpm's. The added benefit is the extra 4-7 when you need it.
TinCup is offline   Reply With Quote
Old 08-26-2015, 06:02 PM   #10
Del in NE Ohio
Thanks guys! I completely forgot about the X2 if rotating the one wheel. 3.78 is what I would expect to find. I installed the 3:54 in my truck a year ago. It did make things a little less effort at 45-50 MPH. If I had it over, I might have opted for the 3:27, but that is some serious $. Thanks again!
Old 08-26-2015, 06:15 PM   #11
Mitch//pa
I put 3:54's in Lucy ( Tudor) with an HC head, it does relieve the R's but would go with 3:27's next time around. I'm not looking to blow any axle keys out of the hole
Old 08-28-2015, 08:53 AM   #12
modelAtony
modelAtony's Avatar
I put 3:27 gears in my 31 Tudor back in 2001 and turned my car into a great driving experience. They advertise that the gear will give you 10 mph extra speed. Wrong it will be 7 mph but 7 extra mph is really great in a bone stock A. Through the years have added other up grades, check my avatar info. Have fun modelAtony tony white Lafayette, LA
modelAtony is offline   Reply With Quote
Old 08-28-2015, 09:40 AM   #13
Tom Wesenberg
I put 3.27 ring and pinion in my friend's pickup, and would also like to build a 3.27 rear end for my car.
