08-19-2015, 01:22 PM | #1 |
valve sticking
my friends model A's and other Fords are having problems with valves sticking..anyone have answers..is it fuel type or is there a additive you can put in to fix it...thanks
The only thing worth learning is what you learn after you know it all !! |
08-19-2015, 01:31 PM | #2 |
Re: valve sticking
Marvel Mystery oil 4oz per tank full .
DAVE |
08-19-2015, 01:40 PM | #3 |
Re: valve sticking
mmo as mentioned in the other post is perfect for that problem, also use a high detergent oil such as havolene 30 or 40w, I like 20 50 myself, that's what I run in all of my classic cars, all 4 of them
08-19-2015, 01:49 PM | #4 |
Re: valve sticking
Most often caused by VARNISH deposits, pop off the manifolds, flush stem/guide, with BERRYMANS' CHEMTOOL, follow up with penetrating oil.
Bill W.
08-19-2015, 02:12 PM | #5 |
Re: valve sticking
Marvel mystery oil did not help, we are now running 100 LL airplane fuel in all cars because ethanol melts tank treatments...maybe the fuel is too clean??
08-19-2015, 02:27 PM | #6 |
Re: valve sticking
Aircraft fuel is very expensive, I would explore options.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
08-19-2015, 02:32 PM | #7 |
Re: valve sticking
MMOil I go glug glug glug before I put 5$ in. That much doesn't cause smoke and runs good on the "crap" gas. FWIW
Paul in CT |
08-19-2015, 02:42 PM | #8 |
Re: valve sticking
You can't find non-ethanal in your area ? Many stations sell it in their high octane fuel. Marina's also sell it, its more expensive.
If you don't like the MMO, then you could try AFT or Sea-Foam. |
08-19-2015, 02:46 PM | #9 |
Re: valve sticking
hey Lopez, mmo wont fix the problem in a few miles, you will have to put a 100 miles or so on the engine. a sticking valve can be caused by the valve with a bunch of varnish on the valve stem, or a slightly bent valve stem, or even the lifter it self sticking, thus the reason for the high detergent oil and the mmo used together, mmo says 4 oz to ten gallons of gas, but you can go to 14 or 15 oz to ten gallons with out any problems, the engine has to be run at operating temp for at least 30 min or longer, when you change oil add one qt of mmo to your oil, just take out one qt of the oil needed for the change and replace it with mmo, since mmo it thinner than the oil most use just go a grade thicker, like use 40w oil instead of 30 weight, and so on, just use a heaver oil ,im going to get a lot of negative repiies because I said to use mmo, but that's ok, I know it works, been using it for over 50 years
08-19-2015, 05:51 PM | #10 |
Re: valve sticking
Sea Foam. You can add it to your gas and oil so you can attack your sticky valve from BOTH sides...
08-19-2015, 06:03 PM | #11 |
Re: valve sticking
hey Y block, same with mmo, easier to find and cheaper
08-19-2015, 08:40 PM | #12 |
Re: valve sticking
Hey Bill, nice t see your still around, and as usual not much tact, straight to the point and telling it like it is, LOL
08-19-2015, 10:29 PM | #13 |
Re: valve sticking
Try a smokeless 2-cycle oil in the gas. Up to 20:1 is possible.
08-20-2015, 12:18 AM | #14 |
Re: valve sticking
MMO wil fix it over night.
A old push style oil can with a small hose to slide over the spout, with a 3/16 hole in it. Start the car and let it run at fast idle, and stick the little hose in the carb, and turn open the oil can top just so the carb will suck some oil in the motor, and when it really smokes, shut the engine off and leave it set. That has always done it for me. Putting it in the gas is all right, but takes to long. Herm. |
01-10-2016, 04:07 PM | #15 | |
Re: valve sticking
There is way more lead in that then was ever in leaded auto-fuel. Ream the carbon out of the valve guides and use MMO in the engine oil or CAMGARD. http://www.aslcamguard.com/ Last edited by GPierce; 01-10-2016 at 04:13 PM. |
01-10-2016, 06:04 PM | #16 |
Re: valve sticking
A can of Sea-Foam in the gas and another can in the oil. It could be a quick easy fix. Also try spraying the valve stem under the valve head by removing the spark plug.
01-10-2016, 06:45 PM | #17 |
Re: valve sticking
100 octane in a low compression engine? If you can't find good gas, I think on the web
I read how to remove corn crap out of gas? |
01-10-2016, 07:22 PM | #18 |
Re: valve sticking
Seafoam in my gas and oil... Along with a thermostat has help.... Less little sounds... You'll see a lot of gook when you drain your seaform/oil mix., oh and if you can find it 100% gasoline... I'm done with corn laced gas...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
01-10-2016, 10:10 PM | #19 |
Re: valve sticking
Hi Dick MMO is the way to Go! These are Model A's not airplanes. Are you having a tour of the Island this year? It was a lot of fun. set it up.,We will be there Hi to Chris too.
www.whidbeymodelaclub.com |
01-10-2016, 10:44 PM | #20 | |
Re: valve sticking
Lead was added in the old days to up octane ratings BUT, it is also an EXCELLENT high temperature lubricant for valve stems/guides. IF YOUR VALVES ARE STICKING, THEY ARE SETUP TOO TIGHT. MMO may or may not allieviate the problem depending on how tight they are. |
