Old 08-18-2015, 06:44 PM   #1
russcc
Default Exhuast port dividers
I plan to do a little cleanup in the exhaust ports on the 59L I am building. What is recommend as a source for the exhaust port dividers. Someone suggested Speedway, but I believe a lot of their stuff is imported today. Rather find an NOS, NORS USA source. Thank you.
russcc is offline   Reply With Quote
Old 08-18-2015, 06:59 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Exhuast port dividers
You might want to reconsider installing exhaust port dividers as they may make very little difference in engine performance and are more trouble than it's worth.. Here's some good reading.
http://www.midstateantiquestockcarcl...at_heads9.html
Old 08-18-2015, 07:16 PM   #3
Pete
Another article by someone that obviously, (and said so himself) has never done it. Some other bad info in the article also.
No, you do not need them in a street engine but they help if you are willing to do it right and make your own.
Yes, they definetely help in a race engine.
Old 08-18-2015, 08:30 PM   #4
19Fordy
19Fordy's Avatar
If possible, please post a link to an article on how to install them correctly so they do work. I have a set of cast iron dividers but have never installed them. Plus, I read somewhere that installing dividers changes the "flathead"sound of the engine?
I did find this additional info. on Fordbarn search.
http://fordbarn.com/forum/showthread.php?t=127590
HAMB had this: http://www.jalopyjournal.com/forum/t...to-use.770337/
Old 08-18-2015, 09:35 PM   #5
Ol' Ron
Ol' Ron's Avatar
The reason for the dividers is to prevent the output of one cylinder form contaminating the input charge of the adjoining cylinder while the exhaust valve is still open. Thus, this is very dependent on the exhaust valve timing and only helps when a very long duration cam is used and then only at WOT.
Now installed correctly they probably won't cause any trouble. However if they come loose, you'll have to tare down the engine to fix it. Good luck.
Old 08-18-2015, 10:06 PM   #6
Pete
I don't think there is an article anywhere on how to do them right. It would take several pages to describe the process.
The ones that work are home made. There are several ways to hold them in efficiently. Whatever works for you is the way to do it.
They should be no more than an 1/8 inch thick. I make mine from Inconel. They run cherry red because there is no water around them like the port walls. I have seen 5 hp gain at 6000 rpm with them.
I have never noticed any change in exhaust sound with or without.
Old 08-18-2015, 11:58 PM   #7
ford38v8
ford38v8's Avatar
pete, have you ever done the heat riser manifold described, or heard of it's relative value?
Alan
ford38v8 is online now   Reply With Quote
Old 08-19-2015, 01:53 AM   #8
Vics Stuff
Vics Stuff's Avatar
I installed a set in my motor 25years ago. Have not had any issues. Was told that they will help to improve exhaust scavenging. Not sure if they really helped or was a waste of time but wanted to build this motor correctly the first time.
Vic
Vics Stuff is offline   Reply With Quote
Old 08-19-2015, 05:44 AM   #9
JWL
I included several pictures and a description of proper installation and retaining methods in my book "Flathead Facts".
I also covered the subject of how much, little, or non-factor importance to assign to this subject.
JWL is offline   Reply With Quote
Old 08-19-2015, 01:57 PM   #10
Pete
No and no.
Old 08-19-2015, 03:19 PM   #11
Bassman/NZ
Bassman/NZ's Avatar
Which every person with a flathead V8 need to read.
Bassman/NZ is offline   Reply With Quote
Old 08-19-2015, 03:34 PM   #12
russcc
Have JWLs book, will check it out. Thank you.
Old 08-19-2015, 03:56 PM   #13
jimTN
I have successfully ran them and presently have a set in a 60 over four inch engine. IMHO it is important to grind/fit them so that they fit square on the port bottom with a countersunk hole on the top. I run a allen scred down in the stud hole and then jam the stud on top of the allen screw. I have a set of speedway dividers on the shef that appear to be well made of bronze. They have made my engines run cooler and caused no problems.
jimTN is offline   Reply With Quote
Old 08-24-2015, 07:33 AM   #14
Diavolo
Diavolo's Avatar
Just my 2 cents.
I have some, not going to use them. Joe Abbin is a local guy here and has written a few flathead books. According to him, the improvement is minimal at best, not worth the effort. As per his guidance, They are in the bottom of the spare parts box, will probably get thrown out.
Diavolo is offline   Reply With Quote
